The clock settings and choices are within the "widgets". Rest a finger lightly on the screen for 1 to 2 seconds and the widget mode will become visible showing clock and other widgets.
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Just go thru the call log and look at each call, then the message indication icon in the lcd disappears and the red lights stop flashing on all the phones, but only after you have looked at each one and the message icon in the lcd goes away above each call. Happy New Year
well i had only the clock icon flashing and after setting the date and clicking an enter on it disappeared my battery icon's all good...about the battery thing i would recall what happened before the icon started to flash might be helpful maybe the inner spring got a damage or the upper sheet metal or membrane as you please has something... cause it happened to me couple of years ago but it got solved and i cannot remember how sorry...definitely there is an easy solution cause i had not had to take it anywhere...
Atomic clocks are tricky. The clock defaults to PST.
Turn OFF the atomic time feature (The little radar icon will disappear) Make sure that you have clicked the DST/TZONE button on the back of the clock to YOUR timezone (a P,M,C,or E icon will appear on the front screen.) Then turn the atomic feature ON and hopefully - all is well!
Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen.
Tap the calendar/time icon (the blue icon, second from the left).
Tap the large clock icon (on the right)
Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
Remove all games from the Nintendo DS.
Turn the system on by pressing the POWER button.
Tap the calendar icon at the top of the screen.
Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
