Question about Dell Computers & Internet
Dell xps 12 battery care disable - Dell Computers & Internet
  • Dell Master
  • 5,327 Answers
What does care mean, in this context?
what is the problem first then ask what to do?
this notebook has huge super flat internal battery
we must dismantle the PC to get to it and replace it.
this is #1 failure on all portable PCs and Cell phones made.
they can fail in 1 years use, (your battery maker proves that on their web site and why, mostly due to abuse)
Posted on Jul 03, 2019
SOURCE:
I need to download manual for Dell XPS laptop
Try Googling (dell)(model)(manual) without parens.
Mar 27, 2018 | Dell Computers & Internet
Dell inspiron xps laptop can't unmute
Look in device manager> sounds> disable the device and enable. remove any external speakers/headphones.
Nov 13, 2012 | Dell Inspiron XPS PC Notebook
My dell xps 410 will not go online thru either of the ethernet ports on the computer. im using my phone with usb tether and it goes online fine. it says it need the ethernet controller driver but...
Hello, look at this link, you should have installed the bottom driver, but take care! if you've got a LAN card as well, you might have got the MOBO one disabled in bios, so best to take out the LAN card, find out what it is and look for a driver for it, meanwhile, with it removed, install the LAN driver for the MOBO LAN port, (bottom driver on this link ) and see if it appears in your 'Network Connections' (Check in bios to see if it's been disabled, though)
Regards, nicam49
The link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_9200_XPS_410&os=WW1&osl=en&catid=&impid=
Aug 22, 2011 | Dell XPS 410 PC Desktop
Dell xps battery not charging
Hello:
Maybe your battery is ruined. Batterries tend to lose their capacity and appear not charging. This occurs after a year or two. It depends on its use and care. Maybe, you need to replace it. You may notice this entering BIOS setup by pressing F2 key after power on your Dell XPS. Then, check battery health on the BIOS menu and follow the recomendations.
I hope this helps. Thanks
Feb 08, 2011 | Dell XPS M1530 Laptop
Ac/dc power plug replacement for a dell XPS m1530 laptop
It would be stated as DC Power Jack.
For the Dell XPS M1530 it has a circuit board that is removed.
The circuit board also has the I/O USB ports on it.
(Input/Output)
DC Power Jack I/O USB Circuit Board example,
http://www.parts-people.com/index.php?action=item&id=5400
A lot more convenient for replacing the DC Power Jack.
Examples of a Dell XPS M1530 DC Power Jack,
http://www.discountelectronics.com/index.php?l=product_list&c=4527
Round and Octagon.
Dell XPS M1530 Service Manual. (From Dell Support)
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/index.htm
1) Remove ALL electrical sources. AC adapter (Charger) and Battery.
2) Use an ESD wrist strap, and connect the alligator clip to a good ground source.
(Cost averages from $3 to $12. I connect to the metal frame of an empty desktop computer case)
3) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s came out of.
(You can use a clean egg carton in a pinch. Label each each holder)
There may be as many as 60 screws, and 12 different types of screws.
DO NOT mix them up.
4) Make notes and drawings as you disassemble. Use a video cam if available. (Use good lighting)
Nice to have a record to come back to if you are interrupted.
5) I suggest using Solder Wick, (Desoldering Braid), for desoldering.
A lot better IMHO than using a Desoldering Tool.
(Solder S u c k e r tool)
50 Watt of less soldering iron, No.2 chisel tip.
.055 Rosin core solder
Rosin paste flux
Solder Iron stand with a damp sponge, or a damp sponge nearby.
To add;
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 03, 2010 | Computers & Internet
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
Open Questions:
Computers & Internet Logo
16 people viewed this question
Ekse
Clive
Clive
Alun Cox
