Question about Radio Communications
Trying to use my go stick with my iPhone. Put on blue tooth on iPhone but devices is not showing anything many help please
6ya staff
SOURCE:
Anonymous
SOURCE: Conecting Blue tooth phone to acer laptop
Visit this link to download the bluetooth driver http://support.acer-euro.com/drivers/notebook/as_5630.html
Posted on Jan 06, 2008
Anonymous
  • 848 Answers
SOURCE: blue tooth
just go to control panel and enable bluetooth in your pc ...if problem continues there may be some virus in your pc blocking the bluetooth connectivity check and remove it
Posted on Jun 14, 2008
Anonymous
  • 320 Answers
SOURCE: Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Posted on Oct 31, 2008
Anonymous
SOURCE: have my new iphone link with my existing super tooth 2 blue ant h
http://www.blueant.com.au/downloads/manuals/old/ST2_manual.pdf
Posted on Oct 18, 2009
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
SOURCE: dont know how to put device in discoverable mode
I might be wrong, but I think there are some H700 headsets which support smart find. If this is your case, you must ensure that all the bluetooth enabled devices, which have been previously paired with it, have their bluetooth radios turned off. Then, some 5 seconds after you open the headset's boom, the light should become steadily lit, thus indicating it is in pairing mode. Otherwise (i.e. if it doesn't support smart find), with its boom closed, press the call button for some 5 seconds, until the light is steadily lit. Then, open the boom. Either way, turn on the bluetooth radio of the device you now want to pair your headset with, and make it search for new devices. After a while, the H700 should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN or passkey) is requested, enter '0000' (four zeros).
Hope you are able to sort your problems out.
Regards, Carlos
Posted on Jul 15, 2010
How do I fix iPhone microphone Problems with headset and Bluetooth?
Go to the settings on your I phone select search for blue tooth device and at the same time hold down the large button on your blue tooth device until it flashes blue and red keep it pressed until it stays blue then your phone will be pared to you're blue tooth device.
Mar 15, 2013 | iPhone Apps
How to play music in my iPhone 4 via blue tooth
first you must add your iphone in your blue tooth devices.
play your music on your ipnone.
go into the sync menu and make sure it is on blue tooth audio
if not change it to that and it should play.
Apr 28, 2011 | 2010 Hyundai Genesis Coupe
Im just 13 so i cant pay anything but i'd appreciat help, I Would Like to pair my Plantronics 220 bluetooth with my Playstation 3 but i baught it used and do not have any instructions on how
ok first you must turn the blue tooth power to on in your games system menu,then you will have to turn your blue tooth device to discovery mode,to do that most blue tooth manufactures use the power button for this feature,by holding down the power button when turning on your headset for 6 to 10 seconds it should put your device into discovery mode,then you can add or search for the blue tooth device from your game system,once it finds it,it will ask you for a pin pairing code .most blue tooth manufactures use a factory 4 digit pin pairing code,they are as follows,try them from first one because i will put them in order from most common to least common,but one of them will work,they are 0000,1234,1111,or 9999, i hope this helps you have fun gaming
Feb 26, 2011 | Radio Communications
I am trying to pair the jwin JB-TH130 with a MyTouch 4G cell phone and the phone will not recognize the bluetooth device.
You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
Feb 19, 2011 | Jwin JBTH130 Bluetooth Headset
My iphone 4 cannot discover my BlueAnt Z9i. I put the headset right on tp of the phone and it just says "seaching". The headset is on and phone's bluetooth is on as well
First you must turn your power to the blue tooth to on in the phone menu,then you have to put your blue tooth device in discovery mode,most blue tooth device manufactures use the power button,by holding it down for 6 to 10 seconds when turning on the device it should have a solid light the you can add or search for device ,they will pair if you have your power on and your device in discovery mode once they pair you will have to enter a pin or pairing code.Most blue tooth device manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Blueant Z9i Bluetooth Headset
My parrot 3200 ls worked perfectly with my previous Samsung D900 however ive recently changed my phone to a apple 3G iPhone, I managed to connect via Bluetooth which is recognised and can make and receive...
I apologize that you having a issue with your hand-free device.
Let me see if I can address some issue with you and help you understand the reasons why your iphone is not working with your device.
Okay blue tooth comes in many flavors and many abilities.
The iphone is not fully compatible with this device and several people as yourself have complained about this issue, currently as of late there was no work around.
Now the iphone uses blue tooth that the parrot just does not fully communicate well with witch causes this issue where you can hear the person but they cannot hear you. This compatibility issue has many people upset.
Now there may be a upgrade witch I will provide a website you can go to.
http://www.justcarkits.co.uk/
Now I cannot guarantee that any said upgrade will work, I am just going by real life results so I hope the information I give here does help you understand. I also hope things goes well in trying to upgrade/update this unit to your satisfaction.
if you have any questions please get back with me.
Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 28, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Copying contacts Vodafone 810/iPhone
Have you tried transferring contact via "bluetooth"?
If both device support "blue-tooth" capability, you may be able to pair both devices and transfer contacts from the source to the target, without imputing anything.
Hope this helps! Thanks.
Mar 19, 2009 | Cell Phones
IPhone 3G bluetooth problem
the iphone 3g bluetooth is at present for headsets/handsfree devices only and cannot link/pair with anything else (phones/pc etc) it has been deliberately crippled to force file transfer etc to be done exclusively through itunes
Jul 15, 2008 | Apple iPhone 3G
Blue tooth
The iPhone is supporting Bluetooth v2.0, but for headset support only.
See the iphone specification here:
http://www.gsmarena.com/apple_iphone-1827.php
That's mean it can use the bluetooth to connect only, with bluetooth headset.
Dec 28, 2007 | Apple iPhone Smartphone
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
