Sony PlayStation 2 Slimline Console Logo
Anonymous Posted on Aug 18, 2009
Do you know where the solder point on a new laser lens is located that has to be removed?
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Aug 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
15140
Points
22
It's opposite the ridge where the type of lens is scribed (PVR-802W, KHM-430)
It's a silver blob, you'll find it easily enough!
Testimonial: "Thanks for the help! "
Unable to read disc
If your console is unable to read disc, then there seem to be a problem with the console, and the problem most likely is as a result of a bad laser/lens inside the console.
To replace the lens of the nitendo wii console, remove the two flip up panela on the side of the wii to reveal the black face plate with the controller ports and memory card slot.
Then remove the three screws located underneath the flip up panels using the fine phillips head screwdriver, then remove the black face plate.
Then remove the two tri wing screws located underneath the face plate. There are also two phillip head screws under the face plate but you can leave them in place.
Use a scalpel to peel off the two white stickers that are covering the screws located near the two front rubber feet on the bottom of the wii. This will reveal two black tri wing screws.
Use the scalpel to remove the two back ribber feet on the bottom of the wii, this will reveal two silver tri wing screws. Remove the two black tri wing screws and the two silver tri wing screws revealed on the bottom of the wii.
Use the scalpel to remove the rubber foot that is covering a screw in the top left corner at the back of the wii. Remove the screw using the fine phillip head screwdriver. Then use the scalpel to remove the white sticker covering the screw directly below the bar code on the back of the wii. Remove the screw with the tri wings screwdriver. Then use the fine phillip head screwdriver to remove the screw that is holding the battery cover in place on the back of the wii. This will reveal another screw that you can remove with the tri wing screwdriver.
Remove the front face plate of the wii, be careful because it is still attached to the console by a black and red wire. Disconnect the wires by lightly pulling on it. Remove the wii shell casing by gently lifting the separating it from the internal electronics of the console.
Remove the DVD drive by taking out the four corner screws using the large phillip head screwdriver then lift up the DVD drive and disconnect both power cable and ribbon cabble connecting it to the console.
Turn the disassembled console upside down, remove the two screws holding the DVD citcuit board in place, disconnect the three ribbon cable that are attached to the DVD circuit board, Use the tweezers to free the wires that are still connected to the circuit board from the plastic clips, Lift up the DVD circuit board and remove it from the way, then remove the lens case that is holding the lens ribbon cable in place.
Use the tweezers to remove the lens casing by lifting up on one side hooks that are holding it in place. This will reveal the laser lens unit, Which is held in place by two metal bars. Take out one of the metal bars by first removing the screws located next to it, and then gently lifting up on the plastic tab so you can slide it out.
Remove the laser lens unit and turn it over to reveal a white plastic part held in by a screw. Take out the screw so you can remove the white plastic part. You will need the part to install the replacement lens.
Attach the white plastic part from your old lens to your new lens using the same screw from the old unit. Place the new lens in the console and reassemble The DVD circuit board.
Remove the two solder points located on the lens ribbon by using a hot soldering iron.
Then reverse the process to reassemble the console.
Take care and good luck.
Hope this was helpful
Ps 2 slin not spinning just replace old laser by new one
Sounds like either you got a bad laser, or if the anti-static solder point on the left side of the new laser was not removed with a soldering iron, then the laser will not work. Simply heat it with an iron and maybe some solder wick and you should be good to go.
2helpful
My Slim PS2 discs won't spin. I just replaced the laser...
put some wieght on the ps2 disk cover flap eg a game cover that fixed mine otherwise i would trash it man ;)
Problem with PS2 SCPH 75001
You will need a Magnifying glass, Flashlight, Toothpick, and Paper towels.
What you need to do is access your laser, and make sure the laser optics are clean. Using the magnifying glass and flashlight, inspect the lens for dust, smudges and lint. Using a Toothpick with a small piece of paper towel swab the lens to clean it. If you need a Cleaning solution, use Windex. If this does not solve the problem, Get a new KHS-400C laser from Ebay. When the new laser arrives, you will need to remove solder blobs from the ribbon circuit strip on the bottom of the laser. These are two small solder blobs near the Ribbon cable connector. I do this with soldering iron, Vise ( to hold the laser), and Solder wick.
PS2 slim
Hi Krazylovin45,
here is your solution. The New Laser lens has a solder blob added to keep static from destroying the laser diode. You will need to remove the laser once more and get some solder wick and a soldering gun. Look on the outer edge near the grooved edge and you will see a solder blob on a narrow strip of ribbon cable. You need to remove this solder to get your new laser to work. If you need pictures, google "PS2 Laser Solder blob" and you should get some links to pics.
www.PlaystationClinic.com
1helpful
2answers
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
2answers
1helpful
2answers
PSP Anti-static solder point removal
it is helpful if you get some desoldering braid from your local diy shop. you just heat the braid on the solder joint and .... zip... the solder runs up the braid.
hope this helps
danolsta
1helpful
2answers
SLIM PS2 MOTHER BOARD REFUSES TO PUMP ITS LENS WELL
when i turn on the ps2 slim the disc doesn't spin and the lens doesn't light up or move and, nothing comes on the screen. its almost as if there is no power to the optictical boards at all. how can i test it? can i transplant another setup into it?
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
