The sun symbol is heating, an icicle is cooling, the fan symbol means fan only. A triangle means auto mode, the machine will heat or cool to get the temperature you have selected. Looking at your remote, it is set on 16 degrees cooling. The large fan symbol will mean its on high fan speed.
Fan symbol - defrost (fan only - does not use thermostat) Fan symbol within a circle - fan forced oven 3 little triangles - static grill (keep oven door open) 3 triangles above the fan symbol - fan grill (keep door closed)
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols: 1. fan leaves - Fan only 2. Rain drop- Dry mode 3. Snow flake-Cool mode 4. Sun- Heat 5. A or AU- Auto mode.Helpful?
To get cold air set temp 23 degree and mode "cool". Now symbols: 1. fan leaves - Fan only 2. Rain drop- Dry mode 3. Snow flake-Cool mode 4. Sun- Heat 5. A or AU- Auto mode.
Ok the snowflake means that the unit is cooling. The sun means that the unit is heating, the raindrop means that the unit is dehumidifying, the fan means that the unit is using the fan only as ventilation without cooling or heating and the funny triangle looking thing is auto mode where the unit sets the mode automatically. The little bar in the middle displays fan speed and the two little arrow things next to it means that the fan is in auto mode where it sets the speed automatically. There I hope that that helps.
I take the time to answer your question, so please rate me.
Thankyou Mat
You need to ensure that the LCD displays a sun symbol. If this is not the case this can be corrected by using the button which has triangle, snowflake, sun and raindrop symbol, press until sun is on screen. Then set temperature.
I take the time to help and answer your question so please rate me
Thankyou
Mat
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
for what model and make?
