While opening the laptop, dust/moisture may have accumulated on the contact points to the battery, hence LED is lighting up since power is reaching till there but does not continue to the battery. Another soln is to keep the laptop operating on the battery till the battery is completely drained of charge. Remove the battery for a couple of hours & after cleaning the battery connection points replace & switch on the AC adapter & check the battery charge without using the laptop to see if the charge has gone up or not, else the battery could be a fake( or Chinese) ...........sodeep
I would check to make sure the AC adaptor connection on the motherboard was not damaged when you opened the pc. ( I have done that a few times.) I'm uncertain of what you have done to solve the problem. Since you have the new battery, again try to charge the battery. when it show the charge is complete, let the pc run until it goes off, when it does, keep powering your pc on until it will no longer power on. (You want to make sure the battery is completely drainned.) Once complete, try plugging the AC to your pc and monitor the charge. You may need to let the pc charge for at least 2 hours before powering the pc on.
Good Luck
C2Solutions
it's connected and the charging led is working
i don't know what's the problem
now the battery is 0% and it won't goes up
