Hi Folks I'm trying to burn a half-hour long DVD with Roxio myDVD but every burn keeps jumping or skipping and the sound gets out of sync.
I've tried messing about with making an image file and burning that but doesn't seem to help.
It worked fine with shorter projects so I'm wondering if it's the size of the file or something.
any ideas?
There may be a problem with incompatibility between the make of DVDs you are using and your DVD player. What make of DVDs are you using? Not all DVDs are of equal quality, Verbatims and Tayo Yuden are considered among the best., Maxell, memorex and store brands are at the bottom of the barrel.
Also how long in time is the video on the DVD?
SOURCE: The Certificate File is missing or Corrupted.
U have error in or installation or ur software hsd missing their some file.First u wninstalled ur previous version then installed newly
SOURCE: roxio creator 2009 burning issues
Here's a few things you can try:
1.) Download Service Pack 3 for Creator 2009. This updates the software and is recommended.
http://www.roxio.com/enu/support/c2009/software_updates.html
2.) Update your CD/DVD burner drives. This can be done by going to the manufacturers website and checking for updates. (Ex: If you purchased your computer from Dell and it came with a built in burner, you'd check Dell.com for updates.)
3.) Update the PX Engine. This is Roxio software that communicates with the CD/DVD burner drives.
http://kb.roxio.com/search.aspx?URL=/content/000070GN&PARAMS=set-locale=en
4.) If all else fails, try visiting this KB article:
http://kb.roxio.com/search.aspx?URL=/content/000008GN&PARAMS=set-locale=en
SOURCE: I have roxio creator & my dvd 9.0 de ; how do i burn my movies
I am trying to burn a movie onto a dvd using Roxio easy cd & dvd burning. The problem is that when I do burn it, it burns as a data disc. I try other things on it and it says to use the disc copier application to burn a dvd. I have searched everywhere on this progmram and there is nothing that says disc copier.
SOURCE: Problem burning ISO image to disc in Roxio... dll?
I would suggest following the instructions found on Roxio's knowledge base
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000008GN&PARAMS=
SOURCE: keeps asking for blank dvd
check roxio configuration the check if it is using the right drive.
sometimes the burner programs try to burn discs in virtual drives.
