Televison & Video Logo
Hussein Maina Posted on Jul 02, 2019
Which universal remote control is compatible with aucma dvd play
5 Related Answers
Anonymous
  • 70 Answers
  • Posted on Feb 17, 2008
SOURCE: Universal Remote Control CODE
You would need to contact the company that makes the remote and maybe Cyberhome for the code.
Anonymous
  • 8 Answers
  • Posted on May 25, 2008
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Anonymous
  • 78 Answers
  • Posted on May 30, 2008
SOURCE: GE Universal Remote Code for my Insignia DVD Player NS-DVD1
if you have already tried "code search" then you may have to return that remote and get a different name brand of universal remote.
Anonymous
  • Posted on Jul 20, 2009
SOURCE: Universal remote control codes for Nissan rear dvd
remote control codes for dvd player
Anonymous
  • 3 Answers
  • Posted on Nov 16, 2009
SOURCE: Lost sponge bob tv remote control
Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
RCA 4 DEVICE UNIVERSAL REMOTE, NEED 5 DIGIT CODE FOR DVP 3150V VCR DVD COMBO.
Please don't type is all CAPS, it is considered SHOUTING and is harder to read. Thanks.
No one buys Universal Remotes, you buy a remote made for the device, a copy of the original.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.com > itm
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Type: Remote Control ; Manufacturer Warranty: None ; Custom Bundle: No ; Color: Gray ; Model: Philips.
MPN: DVD740VR99 DVD74DVR, DVD740 DV...
Compatible Brand: For Philips
Compatible Model: DVP3150V/37 US$49.91 · ‎In stock
I dont have a remote for a GPX tv/dvd combo model number: TD3220BRS. Does anybody have or know where I can get a universal or gpx remote that is compatible with my device please n thank u???????????
Hey Buddy GREAT NEWS !! I found this page on the internet, & here is the link below at the bottom, below some of the text from the page that I also copied and pasted for you:
Get GPX DVD remote codes! If you have a GPX DVD player and want to control it with a universal remote control, we have the codes needed. A GPX DVD player can be controlled with any universal remote if you have the correct programming guide and the correct remote codes. If the codes below do not work with your GPX DVD player, please leave a comment below with the model number of your remote control and DVD player and we will find you the correct remote code.
http://codesforuniversalremotes.com/GPX-DVD-Player-Remote- Control-Codes-Codes-For-Universal-Remotes
AND AS A SPECIAL BONUS JUST FOR YOU !!! YES !! All the remote codes you are likely to need. These guys will even help you out if you still nee help
Program your universal remote control to a GPX DVD player. Use the following remote codes.
GPX DVD Player 4 Digit Remote Control Codes:
0936
0944
2114
2390
And if by chance this info just doesn't work, please just go to the " CODES FOR UNIVERSAL REMOTES " WEBSITE, as these guys seem to be real " FIRETRUCKIN' GOOD !! "
GOOD LUCK TO YOU !!
Geoff
Where is the eject button on RCA universal remote for DVD?
If eject not clearly marked on your remote it probably does not have the function. You can replace the remote for one that does have the function cheaply. Check packaging to make sure compatible with your equipment.
2answers
Can I operate my DX-DVD2 with my Comcast remote, and if so, what is the devide code for programming same?
I doubt that Comcast remote will work in your Dynex DVD player. You may view the pdf format manual of this remote at this LINK. Click the model no. of your remote control and then click the "download manual" at the top right. Listed there the brand's compatible for that model. Note that the universal remote control has a limitation and only compatible brand listed in the manual can access the unit. Most of the universal remote control has a limited brand compatible most especially in DVD's.
You may also click this LINK to buy an original remote control of your DVD player online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
I have a magnavox dvd can i use my rac universal remote to control the dvd
To ensure compatibility you must access USER MANUAL from RAC Remote.Look inside for DVD code for MAGNAVOX. Most Universal remotes also have an AUTO search mode. These options are usually found in the manual. GOOD LUCK
Need remote control code
Dear sunny79
You can purchase a universal remote control and that should work for sure. And when buying a universal remote u dont need to compulsarily check for code compatability.
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
