6. Playback
(1) Set channel 1 to play.Turn the REC/PLAY key on. Then press the channel key of track 1 (the track you just recorded) to set it to Play (key lit green).
(2) Return to the beginning of the song.Hold down the STOP key and press the REW key to return to the beginning of the song (?p.37 "2. Location").
SOURCE: korg d3200 screen has lines through it making it
This sounds like a failure of the LCD connections at the LCD sandwich. It may require replacement of the LCD screen. If one is careful and is adept at electronics, one can DIY this. Be caareful to keep track of screws and location and be very careful of the cables within the unit. If you are unsure of your capabilities, best to take this to a competent electronics repair shop.
SOURCE: Hi, I send you a message about deleted files from
Hello
Can you explain how did you adjust the space on your computer?
SOURCE: have korg d3200. gray
i'm stuck on the start from cd screen and have the cd but it doesn't do anything can anyone help me?
SOURCE: Korg d3200. I can't play or burn cds all of a sudden. Says no disc after inserting a disc. What up?
It sounds like the drive isn't working correctly. i suggest taking it to a Korg authourized repair shop to get it looked after as they will have better access to the needed parts. You can find one in your area through this link-
http://www.korgusa.com/KorgDealers
No sound
• Are the other devices or headphones connected
correctly?
Check the connections. ........................................ (see p.6)
• Is the power of your amp or mixer turned on?
• Is the [MASTER LEVEL] knob raised?
• Is the Global mode Group 4 "MIDI Local" parameter
turned On?
Check the setting of this parameter.
• Are the bars of Drawbar 1 or 2 pulled out?
Pull out some of the bars.
Also check out this site and scroll down and do the "Factory reset" by holding down the buttons they say... AND please note that you have to hold them for a while during this.
