Ricoh Aficio 1515 All-In-One Laser Printer Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I install the toner cartridge? - Ricoh Aficio 1515 All-In-One Laser Printer
John Lemon
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on May 10, 2017
John Lemon
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
6
Questions
Helped
1480
Points
26
Hi I think this answer maybe help you.
    Step 1 - Turn on your printer and open the front cover.
    Step 2 - Take out the toner cartridge and drum unit assembly.
    Step 3 - Push down the lock lever and take the used toner cartridge out of the drum.
    Step 4 - Unpack the new toner cartridge. Gently shake it from side to side to distribute the toner.
    Step 5 - Remove the protective cover.
    Step 6 - Insert the new toner cartridge into the drum unit until locks into place.
    Step 7 - Gently side the tab from right to left and left to right several times to clean the corana wire. Return the tab to the home position.
    Step 8 - Install the toner cartridge and drum unit assembly into the printer.
    If you want to find more detail, you can go and search V4ink.
Anonymous
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 49 Answers
  • Posted on May 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Cheetah:
Answers
49
Questions
0
Helped
67957
Points
52
Adnan Bhatti
Level 3:
An expert that gotĀ 10 achievements.
President:
An expert whose answer gotĀ voted for 500 times.
  • Master 1,188 Answers
  • Posted on Aug 17, 2009
Adnan Bhatti
Master
Level 3:
President:
Answers
1188
Questions
Helped
410260
Points
3822
I reproduce below the content from Ricoh official website. The instructions to install toner cartridge are as follows:
Note: You can make about 50 copies even after the how do I install the toner cartridge? - char_ric09.gif Add Toner indicator begins flashing, but replace toner early to prevent poor copy quality.
Please read the following warnings and notes before attempting to add toner.
WARNING
  • Do not incinerate used toner or toner containers. Tonerdust might ignite when exposed to an open flame. Dispose of used tonercontainers in accordance with local regulations.
  • Keep toner (used or unused) and toner containers out of reach of children.
  • Iftoner or used toner is inhaled, gargle with plenty of water and moveinto a fresh air environment. Consult a doctor if necessary.
  • If toner or used toner gets into your eyes, flush immediately with large amounts of water. Consult a doctor if necessary.
  • If toner or used toner is swallowed, dilute by drinking a large amount of water. Consult a doctor if necessary.
  • Avoidgetting toner on your clothes or skin when removing a paper jam orreplacing toner. If your skin comes into contact with toner, wash theaffected area thoroughly with soap and water.
  • Iftoner gets on your clothing, wash with cold water. Hot water will setthe toner into the fabric and may make removing the stain impossible.
To replace the toner, follow these steps:
  1. Keep the device switched on and only add toner when "Toner is Almost Empty" is displayed
  2. Open the Front Cover
  3. Lift the large green hahow do I install the toner cartridge? - 00175.jpgo its full extent
  4. Press how do I install the toner cartridge? - 00176.jpghold down the green lever to the left of the green handle
  5. Use the green handle to pull out the Toner Tray slightly then release how do I install the toner cartridge? - 00178.jpghe green lever
  6. Pull out the Toner Tray to its full extent
    Push the neck of the Toner Bottle back towards the device until you can see the top of the bottle
  7. Lift out the Toner Bottle by the neck - being careful not to scatter loose toner
  8. Dispose of the Toner Bottle in accordance with your local environmental instructions
  9. Obtain a new Toner Bottle and shake it gently from side to side at least 5 timehow do I install the toner cartridge? - 00173.jpgli class="h_mi">Remove and discard the black cap and place the Toner Bottle in the tray with the neck towards you
  10. Push the neck back into the black housing of the tray
  11. Push the whole assembly back into the device until it clicks into place
  12. Push the green handle down fully and close the Front Cover
  13. The device will perform a few seconds of internal checks before it is ready for use again
Important:
  • Fault may occur if you use toner other than the recommended type.
  • When adding toner, do not turn off the operation switch. If you do, settings will be lost.
  • Always add toner when the device instructs you.
  • When a message "Add toner." is shown on the display panel, replace the toner.
  • Store the toner bottles in a cool, dry place free from direct sunlight.
  • Store on a flat surface.
  • Do not repeatedly install and remove toner bottles. This will result in toner leakage.
  • Do not shake the removed toner bottle. Remaining toner might scatter.
Anonymous
Level 3:
President:
  • Master 1,126 Answers
Anonymous
Master
Level 3:
President:
Answers
1126
Questions
0
Helped
563477
Points
3418
Open front cover, lift up on green handle to release toner feed mechanism. There is a black plastic release below this unit. Release unit and pull out tray. Take old toner cartridge out of machine. Remove black screw off cap from new toner. Place new cartridge in machine with opening towards front. Push tray back into copier until it "clicks" in place. Lower green handle. Close front cover. Hope this helps.
Installed toner cartridge samsung clx6200fx and it keeps saying install toner what is wrong
Did you get a Samsung toner cartridge or an off brand? Toner cartridges have small chips that tell the printer how much toner is left.. Not all of those chips will work correctly.
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
I have red light the second (toner) and the last lamp (exlamation). The first one i don't care, it was red since i charged it, but since the exclamation is red doesn't do anything and the green...
The toner cartridge is not installed, or the printer detects a toner cartridge error. The error is caused by a defective cartridge, an unsupported cartridge an invalid refill, or a cartridge meant to be used in another geographic region.
If the toner cartridge is not installed, install it. If the toner cartridge is installed, remove it and install a new toner cartridge.
For Cartridge errors, Press and release the right button twice briefly to display secondary error codes.
For further assistance, please contact Lexmark Technical Support.
1helpful
Installed a new toner cartridge to the HP Laser
Yes you must pull it out in order to use the toner cartridge. It is there to protect the toner dispenser component inside the cartridge. You can find how to install/replace toner cartridge printed on the Toner cartridge's carton box.
4helpful
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
