Question about Euro-Pro Shark GI490 Iron
The cord has to be replaced . the model i have has a detachable iron. so all i need is a new cord with the connector.
  • 998 Answers
Try hard ware store
thumbs up
Posted on Aug 17, 2009
SOURCE:
How to replace power cord on a sunbeam 4214 iron
www.laundry.manualsonline.com has free manual
Jun 09, 2014 | Sunbeam Irons
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
My Pro Finish 714 cord was accidentally cut. Is it worth replacing the cord? Where do you get a new cord and can I replace it myself?
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
Mar 04, 2011 | Black & Decker ProFinish X750 Iron
Iron turns off by itself while using it. I have to move the cord around in order for the iron to turn back on.
you may have a bad connection in the cord wires will need a new cord replacement or new iron
Dec 11, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
Iron requires new cord
I don't know what brand of iron you have, but most irons are not repairable. I work for Black & Decker and if you needed a new cord for one of our irons, you'd have to replace the iron.
Unless you paid a small fortune for your iron ($100+) and you can see where the cord on your iron is able to be pulled out without taking the iron apart, chances are you'll have to purchase a new iron.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 14, 2009 | Irons
Sunbeam iron won't power up.
I bought a new replacement iron at Sears for $17.99. It is not worth fixing my old one .
Jun 17, 2009 | Sunbeam Irons
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
Apr 12, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
My iron needs a new cord
purchase it from==
http://www.powercord-manufacturers.com/
thank you for using FixYa
Nov 14, 2008 | Black & Decker Irons
Euro-Pro Shark GI490 Iron Logo
145 people viewed this question
Top Euro-Pro Irons Experts
Bruce Showalter
Sheldon Dedek
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
