Watches Logo
I
Ian Brassington Posted on Jul 02, 2019
I have a kirium model cl111a how do you adjust the time please ?
Matthew Claus
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 02, 2019
Matthew Claus
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
305
Points
7
You probably have a screw down crown. Turn the crown counterclockwise and unscrew the crown. Now you should be able to pull it out. When tightening it back down, don't over tighten, just snug. This is to keep moisture out of your watch. Always have it screwed down unless you are setting the watch.
2 Related Answers
gemineye61
Janelle Schoonover
  • 842 Answers
  • Posted on Aug 18, 2010
SOURCE: need a replica watch strap for my tag heuer watch
Best place that I have found:
http://www.watchbands.com/category.aspx,,categoryID,,25
Anonymous
  • 4 Answers
  • Posted on Aug 02, 2011
SOURCE: I have a Kirium F1
My previous Kirium F1 had this problem as well.. got it fixed by my watchmaker for a nominal fee (<USD40). Apparently, the push connector needed to be repaired. After the repair, it was "clicking" again and worked fine. However, the watchmaker did warn against pushing the buttons too hard. This is apparently a common problem for this model.
Tag heuer CL111A battery type
The battery for CL111A-0 is CR2320.
Nov 04, 2012 • Watches
1helpful
2answers
Cl111A-0 manual
I have it in PDF file
if you still need it let me know
1helpful
I have a Kirium F1 Chronograph CL111A and it works fine except the upper button has stopped having an audible "click" when you press it, and so , I cannot access some of the functions. What...
On my Kirium F1, the digital display keeps blinking. How do I make it stop, or is this the signal that I need a new battery?
Yup, it means it's time to change the battery. However, if it's blinking despite having a new battery, it could be because the time and date needs to be set.
Here's a copy of the manual for more info :-
http://www.mediafire.com/?qgq1p3329sbe7s1
Hope this helps.
Where do I purchase extra links for my kirium band?
Contact Tag Heur Customer Service at 866-260-0460. They are open 9 AM - 6 PM Eastern Standard Time Monday to Friday
What are the two digital displays on the top of the Tag Kirum F! for??
Use this link and read the info:
http://www.google.com/imgres?imgurl=http://image.vialuxe.com/Newsimages/1965_LRG.jpg&imgrefurl=http://www.vialuxe.com/News/Tag-Heuer-Tag-Tag-Heuer-Watches-TAG-Heuer-Kirium-Formula-1-Watch/315,870&h=260&w=315&sz=20&tbnid=mdhtEFEWdkvSlM:&tbnh=97&tbnw=117&prev=/images%3Fq%3Dtag%2Bheuer%2Bkirium%2BF1&usg=__PEFomHqQ5EXL6ulbCMX7La4FbWQ=&ei=pMuBSsytA4KsjAfZ3LmECg&sa=X&oi=image_result&resnum=7&ct=image
All that is one link.
Rate me, please.
11helpful
2answers
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
