Green indicator light not working on Beko upright freezer TZS 490 - can I try replacing the bulb and if so, how?? Freezer appears to be working properly apart from the green light not being on.
To get the green power light to come on for a Brada mf 183 upright freezer, you should first make sure that the freezer is plugged in and that the outlet is functioning properly. If the outlet is working correctly, try resetting the freezer by unplugging it for several minutes and then plugging it back in. If the fast freeze light is still on, it may indicate an issue with the temperature control or sensor, and it may be necessary to contact a professional for repair or replacement.
The Kelvinator FD830 upright freezer has three temperature indicator lights located on the top right outside corner to show the current temperature range inside the freezer. The green light indicates that the temperature is within the safe operating range, while the yellow light indicates that the temperature is rising and nearing the upper limit. The red light indicates that the temperature has exceeded the safe operating range and may lead to food spoilage.
One of these is a power light. It typically remains on while the freezer is in use. No light means either a blown bulb or no power. The other is associated with the thermostat. But it does NOT indicate that freezer temperature is appropriate. Flickering appears to indicate the bulbs are simply failing. The bulbs are neon, I think, and are not cheap. Some might try replacing such with LEDs. I have seen comment that the bulbs are not long lasting. www.manualslib.com has numerous danby freezer manuals but I do not know your model. Have a look.
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
to be honest the price would not be worth the cost. but yes you can replace bulb. all you have to do is click it off. but do get in touch with manifactors Manual for blub size and info.
