Water leaks from the point where tube goes into the back of freezer. Part of water goes into the tube feeding ice maker and part runs down back inside freezer wall accumulating on bottem, freezing and eventually building up enough that it leaks onto floor in front of freezer. It takes about 10 days to build up enough iice on bottem of freezer compartment to do this
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
