American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water level in bowl too low
How do you adjust this..
woobie dog
Level 3:
President:
  • Master 1,273 Answers
  • Posted on Aug 17, 2009
woobie dog
Master
Level 3:
President:
Answers
1273
Questions
Helped
593132
Points
4197
Hello, W/D, toilet expert, here.
The tank has a water level line cast into the inside back of the tank. That's where your water level should ideally be. Now, there are a variety of water level controllers, so we'll hit on the major ones. But first, a little nomenclature, so you'll know what it isn't. If you remove the tank lid, you'll notice a tube in the middle that's open, and usually has a smaller tube inserted or attached to it. This is the overflow tube, and feeds water to the rim of the bowl. At the base of the overflow tube is the flapper, and it controls the majority of the flushing power. The flapper is operated by a chain connected to the flush lever. When the flapper is raised (flushed), the water level drops. On the left side of the tank is the water fill valve, The water coming from the house via the tubing under the tank goes into this valve assembly. Part of this assembly is the all important float.
Older ones have the float at the end of an arm, As the water level falls, the float falls and operates the water inlet valve at the other end of the float, on the water fill valve. As the level rises in the tank, the float rises with the level and shuts off the water when it gets to it's pre-set level. This type is adjusted by positioning the float either by the screw adjustments on each end of the float arm, or sometimes by bending the float arm.
The newer types have the float either built in, or the float surrounds the fill valve. The one that surrounds the fill valve looks like a very fat donut and is very similar to the older float arm type, just more compact. The water level is set by adjusting the linkage between the float and the water valve at the top of the water control valve.
The newer newer type has all of the floating mechanism built in. But cleverly, there is an external adjustment for raising and lowering the water level. On the side of the tube, there are slots and raised dots on the lower tube. The upper tube has slots on the inside of it. There is a white locking tab between the two tubes. Here's how this one works: (Turn your water off first for adjusting this type). The tube is in two parts, an upper and lower tube. They are held in place by the locking tab, and by the slots cast into the two tubes (they intermesh) To adjust this type, you have to raise the lower portion of the locking tab to raise it off of the locking dots, and than revove it. Then, you push down slightly and twist the upper section to unlock it. Set the level higher or lower, twist the two parts back together, and reinsert the locking tab. The aim is to set the water level at the level mark on the tank. This type can be tricky; you'd do best to turn the water off to adjust this type, and turn it back on once you have locked it back in place.
Best regards, W/D
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1991
Points
I had the same problem with the cinnamaron toilet. Water level in bowl was too low And had serious splashback every flush. I decided to look up the installaion manual since the contractor installed for me and I had a feeling maybe something was missed. PROBLEM SOLVED by making sure the white tube that fills the toilet is inserted into the overflow tube at the top right in the middle as per the kholer diagrams. It was not inserted in there and instead it was filling the tank directly. Once I corrected that then the bowl filled the the level as it should be (no more poo smears in the tank) and no more splashback! Try that out.
5 Related Answers
Fahr Quad
  • 776 Answers
  • Posted on Apr 04, 2009
SOURCE: raising water level in the toilet bowl.
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Fahr Quad
  • 776 Answers
  • Posted on Apr 09, 2009
SOURCE: Low water level in toilet bowl
Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
Anonymous
  • 308 Answers
  • Posted on Jun 17, 2009
SOURCE: super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
slingspade
slingspade
  • 6 Answers
  • Posted on Dec 19, 2009
SOURCE: Toilet bowl does not have enough water. its the
It depends on the design. Some of these have a flapper with a hole in the cylinder on the bottom side. Watch the flapper as you flush normally. You will see a few bubbles come out of the hole and the flapper will drop before the tank is empty.
If this is the case, you can plug the little hole with something, or buy a new flapper without the hole.
Anonymous
  • 760 Answers
  • Posted on Jul 19, 2010
SOURCE: After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Raising water level in toilet bowl Niagara Stealth
the water level in the pan is set by the exit pipe level and if it is raised it will only flow out again to that pipe level
if you are ferefing to the cistern water level
remove the top and adjust the float level or level control unit
1helpful
2answers
Water level in new toilet bowl to low
water level in the bowl( pan) is determined by the height of the sewerage pipe level that it is connected to and is fixed by design and style of the pan
unless you are on about the water level in the cistern( tank) which you can adjust yourself
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
The water level in the bowl is too low after flushing. Can I adjust it somehow to leave more water in the bowl?
Make sure the fill tube in the tank from the fill valve is in the overflow tibe inside tank. The tube allows bowl to fill with water to correct level.
3helpful
Toto Drake does not fill the bowl to the level of other same toilet. Water level in bowl is low.
Water Level Adjustment
1. To adjust, simply turn upper half of valve counter-clockwise to unlock, pull up till water line on valve is level with water line marked in tank, Fig.C then turn clockwise till valve snaps into locked position.
2. Turn on water supply to fill tank.
3. Tamper proof key is optional, and may be used to simply to prevent further adjustment once final setting is achieved. Fig D
2answers
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
4helpful
Apr 09, 2009 • Bemis Home
2answers
Raising water level in the toilet bowl. Crane toilet. Don't see where any adjustments can be made. Water level in reservoir tank is up to the inlet tube. How do i get the water level in the bowl to be...
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
