Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Anonymous Posted on Aug 17, 2009
Washer stops midcycle and displays E:03. Will not drain
Anonymous
Level 3:
  • Master 998 Answers
  • Posted on Aug 17, 2009
Anonymous
Master
Level 3:
Answers
998
Questions
0
Helped
248553
Points
3069
Clean pump and drain hose
Testimonial: "Thanks. This was exactly what was needed. It was smelly, but worked like a charm! Thanks again."
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
434
Points
My bosch essence nexxt washer fills with water and then drains and hen sets in the wash cycle and unlocks
Samsung front load washing machine 5E Error code
If your Samsung washer is in the middle of a drain cycle and the 5E error code shows on your washers display, it means that the water is not properly draining out of the washer. Something may be clogged, jammed, or blocked and thus preventing water from draining out of the washer.
https://removeandreplace.com/2016/11/03/samsung-washer-displays-error-code-5e-message-how-to-clear-error/
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
2helpful
Washer stops midcycle. I need to raise/lower the lid to get it started again. But if I wait too long, that doesn't work.
Would suspect you have a bad lid switch, may instead have a problem with the neutral drain of the transmission, but suspect you only need to replace the lid switch. The control panel is secured at the end caps, usually screw in back, or putty knife in base to release, control panel rotates up, remove whole cabinet if necessary, all front serviceable,(if it stops in the same spot it is in the timer though)
hope this helps
My washer stopped in midcycle and posted the F2 error message. What does that mean? Thanks
You have something in the drain lines. Possibly a coin or other objects.
Here is what you need to do:
- Clean out the drain pump catch.
- Pull the suction boot off the drain pump, clean out any gook.
- Blow through the drain hose starting from the connection at the pump.
- Verify operation or replace the drain pump
Maytag Neptune Washer stops in Midcycle ... water does not drain either
This is more than likely going to be a problem with the pump.The pump is not draining water so the machine isn't progressing any further.The pump may be blocked with something or the pump is seized.
Washer stops in midcycle and F displays, what could be the problem
washers stops in midcycle and F displays whats could be the problem
1helpful
Error 03
water drain problem (check drain hose and pump)
Flashes Ld midcycle
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
2helpful
Oe comes up on the display
The drain filter is located on the bottom left corner behind the little door.  Remove the door and the filter is located there.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
