USE AND CARE GUIDE 4
thdstatic.com
https://images.thdstatic.com > pdfimages
Insert the silicone rubber plug (E) into the hole in the receiver (B) to cover the dip switches. Controller Model: TR221A. ?. Position the house supply wires ...
Hampton Bay 5-Function Universal Ceiling Fan Remote ...
eBay
https://www.ebay.com > ... > Lighting Accessories
Hampton Bay 5-Function Universal Ceiling Fan Remote Control TR221A w/ battery ; Item Number. 325781661328 ; LED Chip Code. Not Applicable ; Power Source. Battery ...
US$34.91 · In stock
SOURCE: can't find codes for my hampton bay universal remote
i need the codes for my hampton universal remote control
needed for my Quasar tv combo
SOURCE: Two ceiling fans, both remotes control the same fan
One of the dip switches is located under the globe, near the ceiling.
The other dip switch is located in the remote control. You have to take the battery out and look in the space where the battery is, usually towards the top of the remote.
On mine, there are four settings, the dip switches have to be in the same position, on both your remote and the fan unit, for them to work. You might have to reset them if you do not want both fans to work from one remote. Maybe one fan and remote have the first switch up and the other three down, that would let them both connect. The other may have the first one down and the others up, then it would only work from the remote that is set the same way.
Usually you can reset them by using the point of a pencil to move each dip switch setting.
SOURCE: cant get universal remote to work with broksonic tv
Code 0115 worked for me on the Phillips PM335 remote FINALLY!!!!!!!!!!
SOURCE: I NEED CODES TO MY WIRLESS CEILING FAN REMOTE
What codes? There are 4 dip switches (see DIP switch wikipedia) inside the remote control and 4 inside the sensor that is inside the fan. They have to be in the same position. If you don't feel like messing with the one inside the fan, keep changing the ones inside the remote. U= Up, D = Down
U-U-U-U, U-U-U-D, U-U-D-U, U-D-U-U, D-U-U-U, U-U-D-D, U-D-U-D, ... D-D-D-D (*There are 16 possible arrangements*) On e of these arrangements will work (has to work) if the remote components are not damaged.
