I have an IPaq 1940. Whenever the main battery went flat, I lost the additional programmes I had loaded, so I bought a spare battery and charged it in the Ipaq - but now when I change over the battery, I still lose these programmes, which I thought the internal battery was supposed to protect for a few minutes. The back-up battery shows it's full in Settings. Am I missing something?
The internal battery is bad, as all are this old>?
what else?
Figure : Charging the battery
NOTE:
The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter
Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
CAUTION:
To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
Figure : Charging with the universal desktop cradle
NOTE:
The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable
Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery
The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
SOURCE: how to change the backup battery of ipaq 1940?
http://www.pdasmart.com/products/19927ipaqparts1900.htm
This PDA is relatively difficult to take apart. I've done it myself and it was very difficult. It is not recommended by any means because you can seriously mess up your ipaq by taking it apart. On the site I gave you after you buy and receive the replacement backup battery, if you do it yourself, will give you a site to get instructions from. You can also send it in to have it done professionally.
SOURCE: Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
SOURCE: iPAQ file store problem
You're not alone! Virtually every ipaq rx3715 gets this problem at one time or another. Unfortunately, it is a massive memory issue. Be prepared to potentially lose all of your data, including programs. My suggestion would be to back up your ipaq before you do this. I do not know if the backup retains the memory error, but what I would do is back it up, perform the fix, and then restore the data back onto the ipaq. If your file store problem is fixed, there you go! If the problem comes back upon restoring the pocket pc, then unfortunately you will lose all data and programs in order to fix the memory, and that will be a personal choice. For most of us, the ipaq simply freezes up upon entry into the file store, so consider yourself lucky that they simply do not delete.
Here is the step-by-step process of how to fix your problem.
1. Download GER and ENG ROMs (latest) from HP's support site
2. Unpack both
3. Cancel the automatic flash procedure.
4. Locate the EnterBootLoader.exe file in the folder of the unpacked GER update
5. Copy it to PPC
6. Run it from the PPC
7. Run the ROMUpdateUtility.exe file from the desktop to start flash procedure.
Then you have a German-language PPC
8. Locate the EnterBootLoader.exe file in the folder of the unpacked ENG update
9. Repeat steps 5-7 for the English update
You're done
Remember, you're not alone! We all had the same problem.
SOURCE: how to switch off my hp ipaq
On most HP pocket PC's, holding the power button momentarily will turn it off.
If you hold it too long, it will only turn off the backlight, but the unit will remain on.
SOURCE: locked out of my ipaq
The Pda is now hard reset and restored to defaults stored in the rom memory. the password and everything else should be gone and it should work as if you had just opened it for the first time.
