hello, i think the tape tab is jammed if you will need help to: Disassembly,Repair, Maintenance or adjustments and more you can download the factory service manual from the below link: http://goo.gl/ubSnD Good Luck
Dear
need not try any tips, as its the problem of mechanical deck, which is giving this problem it needs to get replaced, as the cable on the back of hvr-a1, mecha deck gets broken....
due tow hich the error starts coming...
get that replaced
Hello. This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A ... the cause: the flex is broken. you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
I would need more information to help you. Any warning messages? Any smoke prior to shutdown? Certainly you have a short in the unit somewhere. You could unplug the unit and check all the final transistors for shorts. If not there I would look at the power supply section for problems. Let me know how you make out.
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape
pull-in or eject. Mostly the tape stickers are bad situated over the
stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the
tape is already inside the machine is unable to reject the tape -
disconnect the machine from electricity to open it or call service...
Down-conversion Capability
The HVR-1500 has a built-in down-conversion capability that
allows 1080i recordings to be output as 480i and 576i signals from the
i.LINK and SD-SDI interfaces. These signals can also be output from the
analogue component, composite, or S-Video connectors. This allows 1080i
recordings to be edited using non-linear editing systems running DV
editing software or to be viewed on an SD monitor. When down-converting
the 1080i recording, the aspect ratio displayed can be converted from
16:9 to 4:3. Display modes can be selected from Squeeze, Letterbox, or
Edge crop.
