Question about Motorola Mobility MA 361 Cordless Phone
Phone doesn't ring, no dial tone.
The phone has no dial tone and the red light is flashing. When I call the phone it doesn't ring but the answering machine still comes on.
All the other phones in the house work, so I know it's not the phone line.
I have tried unplugging it and letting it sit, but it still has not dial tone.
Does anyone have any ideas?
  • Carol44 Dec 01, 2007
    Thanks, I will go get a new battery and try that.
  • Anonymous Mar 22, 2014
    no dial tone /rings in/can't answer or call out
    Sergeant:
    Champion:
  • 298 Answers
Try switching the battery wilth a know to be
good battery
Posted on Dec 01, 2007
SOURCE:
Phone #2stoped ringing, no sound when dialing etc .
go back to that base station and ensure that it recognizes the bedroom phone
follow the user manual to install other phones
the bedroom phone has to be the same exactly and not earlier versions or different makes
Feb 24, 2016 | Panasonic KX-TG6632B 1.9 GHz Digital DECT...
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
I have a call back on my answer machine but the red light wont go off it comes up with reorder tone I cant retrieve any of my messages I need help?
Press the message button and this will probably ring another extension this must be answered and the light will go out Or Dial *790 This will clear all local settings including call forward To set call forward on busy no answer dial *7105 (destination number) #
Nov 01, 2013 | Panasonic KXDT321 Phone
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
How to recieve a fax ?
If your printer is connected to a modem make sure that the port has a dial tone. To check for dial tone, try to plug in a phone to the same port that you printer is connected to. If it doesn't have dial tone, you might want to check with your phone provider. Or you can plug in the printer straight to a wall jack.
Once the printer is connected to a line that has dial tone, you can then setup the printer to receive faxes. To set it up, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering.
If you have an answering machine, set your printer to pick up 3 rings higher than your answering machine. If not, set it to pick up on the 5th ring that way you will still have time to pick up the phone if it's a voice call.
If you have a voicemail service from your phone provider, you'll need to contact your phone provider to get a distinctive ring feature. Once you'll have that feature, you can assign a distinctive ring to your printer. You can find that under Fax Setup > Ringing and Answering > Ring Pattern.
May 29, 2012 | Lexmark Interpret S405 Wireless All-in-One...
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
The red light is flashing. when you go to get a dial tone then are 7 or 8 fast beeps then a dial tone. the answering machine says there are no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
GE Spacemaker Kitchen Phone/Radio/Answering Machine Model 26976 GE 1
I would pack it and send it to GE for repair replacement as defective
Mar 23, 2017 | GE Spacemaker 26976 Cordless Phone
No dial tone
I have no dial tone on my phones. I can receive calls and my answer machine works ok. I plugged another phone (an old phone) and I have a dial tone on that phone, but not on the new ones
Apr 13, 2008 | GE 28112 Trio Cordless Phone
Motorola Mobility MA 361 Cordless Phone Logo
460 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
