I need to download multiple files from server to the client using asp.net 2.0.Additionaly i would also like to disable open/save/cancel dialog box while saving the files.
Thanks in advance !!!
Sir,
//To Get the physical Path of the file(me2.doc)
string filepath = Server.MapPath("me2.doc");
// Create New instance of FileInfo class to get the properties of the file being downloaded
FileInfo myfile = new FileInfo(filepath);
// Checking if file exists
if (myfile.Exists)
// Clear the content of the response
Response.ClearContent();
// Add the file name and attachment, which will force the open/cancel/save dialog box to show, to the header
Response.AddHeader("Content-Disposition", "attachment; filename=" + myfile.Name);
// Add the file size into the response header
Response.AddHeader("Content-Length", myfile.Length.ToString());
// Set the ContentType
Response.ContentType = ReturnExtension(myfile.Extension.ToLower());
// Write the file into the response (TransmitFile is for ASP.NET 2.0. In ASP.NET 1.1 you have to use WriteFile instead)
Response.TransmitFile(myfile.FullName);
// End the response
Response.End();
private string ReturnExtension(string fileExtension)
switch (fileExtension)
case ".htm":
case ".html":
case ".log":
return "text/HTML";
case ".txt":
return "text/plain";
case ".doc":
return "application/ms-word";
case ".tiff":
case ".tif":
return "image/tiff";
case ".asf":
return "video/x-ms-asf";
case ".avi":
return "video/avi";
case ".zip":
return "application/zip";
case ".xls":
case ".csv":
return "application/vnd.ms-excel";
case ".gif":
return "image/gif";
case ".jpg":
case "jpeg":
return "image/jpeg";
case ".bmp":
return "image/bmp";
case ".wav":
return "audio/wav";
case ".mp3":
return "audio/mpeg3";
case ".mpg":
case "mpeg":
return "video/mpeg";
case ".rtf":
return "application/rtf";
case ".asp":
return "text/asp";
case ".pdf":
return "application/pdf";
case ".fdf":
return "application/vnd.fdf";
case ".ppt":
return "application/mspowerpoint";
case ".dwg":
return "image/vnd.dwg";
case ".msg":
return "application/msoutlook";
case ".xml":
case ".sdxl":
return "application/xml";
case ".xdp":
return "application/vnd.adobe.xdp+xml";
default:
return "application/octet-stream";
Thanks
Good Luck
