When this happens, quite often the drive structure gets damaged. This type of logical damage is sometimes easy to resolve, if it's worse then you may need the help of a pro but you will have reasonably good chances of getting your data back.
For the simple fix, open My Computer and check if the drive letter is still there, if not you will need a pro, reply back with your Country, State and City and I'll put you in touch with a pro. If it is there, there is a good chance you can perform a simple repair. Assuming it is, Right-Click the drive letter, then select properties. When the properties sheet opens select the Tools tab, then click Error Checking, a small window will pop open, be sure both boxes are checked then run the checking utility.
If you got that far you have about an 80% chance of repairing the drive yourself. If it fails, as with above, reply back and I will get you in touch with a nearby pro.
Hope this helps FixYa,
Chris
