On the back of the Starck+ PH-5016, directly in the center, is a button much like one that would be on a digital watch. Use a pen or other pointed object to depress that button and the hands will spin. Release the button when desired time is achieved. Only runs clockwise, so setting it back an hour might take awhile, but it will eventually get there.
SOURCE: philippe starck with fossil ph-2006
Fossil Contact Information
Main support number 1-800-842-8621
Email support [email protected]
hope this helps
SOURCE: philippe starck ph-1071
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps,
SOURCE: Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
SOURCE: starck watch PH 1071 110504. I just need to
try this link to get help;
http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
Rate, please.
SOURCE: how to change the greeting
press the mode button twice. that will change to date mode. during the date mode display ,hold set for 5 seconds. mission accomplished!
