Usoroh Ernest Posted on Jul 02, 2019
My copier sharp ar5520d displays f02-10 - Sharp Office Equipment & Supplies
2 Related Answers
Anonymous
  • 82 Answers
  • Posted on Apr 06, 2008
SOURCE: Problem with copier SHARP AR-206 display
what is the problem with the display ? is it out ? or showing an error ?
Everett Lin
  • 990 Answers
  • Posted on Oct 01, 2009
SOURCE: Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
AR 5516S SHARP COPIER DISPLAYS BLACK/DARK BACKGROUND ON THE PAPER
check the density settings
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
2answers
Sharp photocpi machine ar5520d devloperisdamage after 4 days
The developer was improperly installed. Please install developer type sharp ar205dv.
2answers
2helpful
2answers
16helpful
4answers
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
6helpful
2answers
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
