Question about Toshiba SD-V291 DVD Player/VCR
Can you record a dvd from vhs on this system ?
  • 146 Answers
No you cannot - This is a DVD *PLAYER* / VCR combo - which means it features a DVD player & VHS recorder in one - you cannot record onto DVD - You can however watch a DVD while recording your tv program on the VCR.
I hope this answers your question.
If you want to convert your VHS to DVD you will need to purchase a standalone DVD recorder - I personally do not reocmmend the DVD recorder / VCR combos - or you can use a HDD/DVD recorder which stores recordings on a hard drive and later you can burn them on DVD, they allow editing, more flexible recording options, etc
Posted on Aug 17, 2009
Testimonial: "Thank you, very helpful. Good explenation"
  • 1 more comment
  • deathdrag642 Apr 29, 2011
    this is highly incorrect cause my father has one and recorded onto the dvd with this vhs and dvd combo it's called dubbing
  • Larry Tymorek Sep 10, 2011
    only if it is a recordable DVD burner. You probably mean he recorded a VHS tape from the DVD end of this combo unit.
  • deathdrag642 Sep 11, 2011
    I have previously done it myself.
SOURCE:
I have a Toshiba DVD Video Recorder. How do I record from a VHS to a DVD?
For a toshiba DVD player there should be a s-video input. For a vhs you must have a vhs player that has a component/s-video output. Hook up the vhs player to the dvd recorder using an s-video cable and press play on the vhs player. Then press record on the dvd recorder.
Feb 28, 2011 | Toshiba Televison & Video
Using a JVC /DVD/S-vhs dual dubbing Deck model jvc sr-mv55u Trying to do a straight dub from an edited S-VHS tape to a formated for video DVD for archival library. I am following the instructions in the...
now days dvd player comes with advace tacnoloy
u not need make vedio dvd u make to your dvd as a data dvd & dvd plyer read it isely so dont need to do vhs or vcd
Mar 29, 2008 | Televison & Video
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
Copy Audio Cd into DVD
Best guess...put audio cd into DVD side, Video tape into VHS side. Set the VHS to record in SP, Then record the cd to vhs. then when you are done recording on the vhs, put a blank DVD in the recorder side, and press dubb to DVD to get it to record from vhs to Dvd.
Jun 24, 2008 | Funai FDRV90E DVD Recorder/VCR
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Toshiba SD-V291 DVD Player/VCR Logo
411 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
