Hello Cal, I sent you the link to download the service manual for your Panasonic
I hope you can place the clip
Greetings Franco Dosil
Hola Cal, te envio el link para que descargues el manual de servicio de tu Panasonic
Espero puedas colocar el clip
Saludos Franco Dosil
https://elektrotanya.com/panasonic_rf-2400_html_sm.zip/download.html
https://www.manualslib.com/download/649026/Panasonic-Rf-2400.html
SOURCE: Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
SOURCE: 1996 ford ranger pickup-splash wiper motor replacement
YOUR VENT COVER SHOULD COME RIGHT OFF GIVING YOU ACESS TO THE WIPER MOTOR AND THE CLIP AND NUT THE CLIP IS VERY TRICKY TO PUT BACK ON BUT WITH COVER OFF YOU SHOULD NOT LOOSE THE CLIP IT WILL JUST FALL IN CAVITY UNDER NEATH WIPER ARM ASSEMBLY GOOD LUCK
SOURCE: Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
SOURCE: broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
SOURCE: The FM antenna is insufficient. I there a way to
To improve reception, use a 75 Ohm outdoor antenna instead of an indoor antenna. Disconnect the indoor antenna before replacing it with an outdoor antenna.
