SOURCE: Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
SOURCE: invacare auriga looses power
Hi. Most probably its the throttle pot ( Wig Wag ) thats causing the problem. I am an Invacare service agent and I have changed these many times for this very reason.Also check motor brushes are not worn down or jaming. Good luck. Neil.
