Question about Archos Internet Media Tablet MP3 Player
My Archos 5 won't turn on
My archos 5 won't come on because it seems to have no firmware but when I download the firmware from the archos site it doesn't update. It says the update failed and doesn't say why. It's not a problem with hard-drive because I transported files from my pc to a friend's using it. I have tried everything and can't fix this problem.
SOURCE:
SOURCE: Archos 404
Did you click menu button and enable usb on the Archos?
Posted on May 30, 2008
  • 5 Answers
SOURCE: Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
  • 5 Answers
SOURCE: Archos 405 2GB isn't recognized by Windows XP computer anymore
Hi. Remove the 16gb SDHC. If you still have difficulties then downgrade the firmware (to original version). You may need to enter
'recovery mode' by powering down the archos then press both power button and volume up button at the same time. Do a disk repair. Shayind4
Posted on Sep 12, 2009
IPOD tech
  • 61 Answers
SOURCE: Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
Posted on Sep 14, 2009
  • 161 Answers
SOURCE: Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
Posted on Apr 13, 2010
Cant download a flashplayer for archos5
Is it archos 5 or archos 5 IT ?
For archos 5 IT is already upgrade to 2.2 as far as I know.
For archos 5 I don't think there is one and with archos they don't bother doing anymore upgrades for older models.
Found this for the archos 5 IT.
http://www.youtube.com/watch?v=GzgfCTp6--k
Aug 18, 2012 | Archos Internet Media Tablet MP3 Player
I was given an archos but can't seem to figure out archos 504
You can download the manual from the manufacturer's web site at
http://www.archos.com/support/download/manuals/english_-_user_manual_-_archos_504-604_-_v2.2.pdf
Jul 24, 2010 | Archos 504 500870 Digital Media Player
Apr 13, 2010 | Archos 5 MP3 Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
Recovery code 101
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
D) On the Archos 5 or 7
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
May 27, 2009 | Archos 5 Internet Media Tablet
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
After formatting the archos5 ,the device doesnt get recognised
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* When the white option screen comes up, just pick the format disk
Mar 16, 2009 | Archos 605 WiFi Digital Media Player
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
HELP!
Can you hear HardDrive clicking?
Oct 03, 2007 | Archos 604 WiFi Digital Media Player
Archos Internet Media Tablet MP3 Player Logo
987 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
