Question about Maytag Washing Machines
My Maytag washer will not work after a power outage. What can I do?
2 Suggested Answers
SOURCE:
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle...
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Dec 27, 2017 | Maytag Washing Machines
Displays on maytag neptune washer and dryer won't come on after a power outage
It may have burnt the main controls out on circuit boards or this sounds silly but check your breakers, did you have a power surge before the outage?
Aug 20, 2015 | Maytag Washing Machines
POWER OUTAGE washer will not turn on
Possibly metal (paper clip or small coin causing earth leakage in water pump. Strip and clean, check all wires for shorting. Recheck plug fuse and motor (could be burnt out).
Dec 08, 2013 | Maytag MAH8700A Front Load Washer
Washer Door won't open
kill the power either unplug it or turn the breaker off wait few minutes hopefully might reset it if not call service... may need new control board or latch mechansim kinda common after power outages when power comes back sends jolt blows electronics out hope this helps
Jan 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer mah5500b would not start after a power outage. it displays a code "do" and that's it. could you please tell me how to fix this?
power outage should not have caused this / but the do is (door) code it either didn't lock . or is unable to lock . the latch assem may have to be leplaced . try turning power of /just unplug and plug back in and try to program .. if it doesn't i would repl door latch .. pls feed back mm
Dec 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer stopped in mid cycle because of a power outage. Now it will not complete a full cycle. When I open the door, there is a pool of water in the tank. I have unplugged it, started it...
Try spin only cycle. Should drain water then spin. If that doesn't work it may be the power outage started as a power spike and fried your control board. Good luck.
Mar 01, 2018 | Maytag Neptune MAH5500B Front Load Washer
Code f-24 is flashin on my washer
I had the same issue, called Maytag they didn't know what the code meant, said it was one that a technician had to come out and diagnose but was probably power related (glitch or outage). I hit cancel twice and it cleared and I went on with the wash with no further incident.
Jul 12, 2009 | Maytag EPICz Electric Dryer
Had power outage and now the Neptune Washer won't even light up. Washer was not in use at the time. Checked the breaker and outlet and all live and functioning. Is there a reset button that will reset the...
no! did the porew surge when it came back on,like the lites in the house went briter than normal/may have damaged main control board in top console.you will also fine a tech sheet up there.see if you can get some glues their.God bless.tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
