Microwave Ovens Logo
D
Danny C Soileau Posted on Jul 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE profile microwave. only one button works on the touchpad. The "add 30 seconds" button is the only button that works on the touchpad. Model number is PEB2060SM1SS
christiaan saayman
Level 2:
Habit-Forming:
New Friend:
  • Expert 132 Answers
  • Posted on Jul 16, 2019
christiaan saayman
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
132
Questions
6
Helped
43413
Points
310
Problem lies on control board
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 16, 2008
SOURCE: G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • 410 Answers
  • Posted on Jun 27, 2009
SOURCE: Touch control failed on GE Spacemaker Microwave HVM1540
If you want to order a touch pad, (it has the micro computer built in it!) and fix it that way, you'll still have a 2-3 year old machine.
I would say it would be quicker and cheaper to buy a new one.
Anonymous
  • 6 Answers
  • Posted on May 02, 2010
SOURCE: no display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 30, 2010
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
Anonymous
  • 43501 Answers
  • Posted on Aug 22, 2010
SOURCE: I have a GE microwave # JVM2070SK02 that the
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
2answers
My controls are locked on my GE Profile microwave oven
ask GE what might be wrong we only know stuff we have seen sorry
tip
Profile series kicks out during operation
My GE Profile series Spacemaker Microwave, model JVM2070BH002 after we set the cooking time will kick out after about 3-5 seconds. This is sporatic. It will work for a week and the kick out for 3-4 times.
Ge profile microwave oven touchpad not working
The touch pad is more than like the problem. This is common. Try removing the ribbon connector and reinserting it back in the receptacle. If this doesn't fix the problem then replace the touch pad.
GE profile microwave keeps alarming "reminder"
test this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2ZpM2PvPs
1helpful
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
1helpful
My GE profile Convention Microwave model JVM1790SK01 dial is loose and does not work. How can this be fixed?
see the information and use the common sense: God bless you
. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
6helpful
2answers
My control panel has locked and I can't unlock it.
If this is a GE Spacemaker model, you can lock or unlock the controls of the oven by pressing and holding the CLEAR/OFF button for 3 to 5 seconds. If this is not a GE Spacemaker, please post back with your correct MODEL NUMBER. I hope this information helps you.
16helpful
2answers
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
