It sounds like it lost its set up, on remote enter set up and press ok and let it re-scan channels again
Making Cash more than $15k to $18k consistently just by doing basic online work. I have gotten $18376 a month ago just by working on the web. Its a simple and basic occupation to do from home and its profit are greatly improved than customary office work. Each individual can join this activity now just by pursue this link……..go to this site home media tech tab for more detail support your heart :*here…………………..===>>>www.gocash7.com+
Don’t copy "+ " with web address
SOURCE: humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
SOURCE: Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
SOURCE: I have a philip magnavox model 9p5034c103 and the
what is the diffrent between nokia ultra and flexi bts.
SOURCE: RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
SOURCE: Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
