How do I get it to quit and to start washing dishes?
There are several touch pad buttons that could activate the Child Lock feature on a Kitchenaid dishwasher. To toggle off the lock, try pressing and holding the 4-hour delay dry or the energy saver dry key pads for 4+ seconds. The Energy Saver Dry is used for the Child Lock on the Kitchenaid KUDS25SHWH1. This manual is here: https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L9050329.pdf . The 4-hour delay or Control Lock options are listed in this manual: https://www.kitchenaid.com/content/dam/global/documents/201605/owners-manual-W10596243-RevD.pdf . If neither of these steps work, you may have a problem with the keypad, the wiring between the keypad and the control board or the control board itself.
Please add a comment with the model of the dishwasher if you'd like me to try and find the parts list/diagram. If the machine is under warranty, you may want to contact Kitchenaid.
I hope this helps.
SOURCE: Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
