Fisher and Paykel GWL11 Top Load Washer Logo
C
Cathy Hardage Posted on Jun 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My FP GWL11, beeps repeatedly at the end of the first wash cycle, then stops.
Peter
Level 2:
Champion:
  • Fisher and P... Expert 203 Answers
  • Posted on Jul 11, 2019
 Peter
Level 2:
Champion:
Answers
203
Questions
0
Helped
97364
Points
471
It beeps to tell you there is an error. While it is beeping & before pressing any buttons, read the error code & write it down. The error code is the lights along the top row. Count from left to right and make a note of exactly which lights are on and which are off. There are 8 lights, you need to say exactly which number light is on. Post the result back here and someone will tell you what that error code means.
5 Related Answers
A
Anonymous
  • Posted on Jan 05, 2007
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Anonymous
  • 1294 Answers
  • Posted on Nov 27, 2007
SOURCE: End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
l blight
  • 28 Answers
  • Posted on Jul 03, 2008
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Anonymous
  • Posted on Aug 04, 2009
SOURCE: Zanussi ZWF16581W Washing Machine
Not helpful as the instructions given in the manual do not work. It may be that they do work at a certain point but they don't tell you WHEN to press them. When the machine has irritated you beyond belief in beeping like a maniac? Before you start the cycle? during the cycle? When? Have tried all of these but to no avail. What am I missing?!
Anonymous
  • Posted on May 27, 2012
SOURCE: how do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
Fisher & Paykel GWL11 intermittently overfills on wash cycle, cold water doesn't shut off.
That sounds like the cold water valve has failed. Replace it and you will fix your problem. Those valves were not designed to be repaired.
2helpful
The washer will go through the wash cycle, but will not rinse or spin. The machine stops and beeps with the red light at the end blinks while it beeps until i stop it. Please help!!
HI - A RED LIGHT ON ITS OWN MEANS THERE IS A COMM PROBLEM BETWEEN THE DISPLAY & CONTROL MODULES. THE FAULTY UNIT WOULD BE THE DISPLAY, THIS IS A TOUGH ONE BECAUSE THIS DOES NOT ALWAYS WORK, OFTEN THE ACTUAL PROBLEM IS THE CONTROL MODULE ITSELF.
I WOULD BE INCLINED TO REPLACE THE CONTROL MODULE INSTEAD..
CHEERS
Gwl11 washer
Code 248.there should be paper with fault codes inside the control box area if you undo it by 2 phillips head screws.
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
