SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
SOURCE: no electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
SOURCE: JBL Creature 2.1 Left Speaker not working
Hiya
Too late to resolve the original poster's worries, I can assume, but I arrived here when searching on account of the same problem and resolved it. This is going to sound implausibly condescending, I'm afraid (and excuse th elack of technical terminology!)...
I couldn't get my left speaker to work exactly as above, but then looked carefully at the shape of the respective cables leading to the sub. You have to fit the triangle shape of the lead into the triangular shape of the hole. The speaker CAN be connected what *feels* like correctly, but is in fact connected incorrectly (ie, not all the way in).
This is more a problem with the left speaker than the right since it's a triangle and the right is a square, and can be a little fiddly.
Anyone else experiencing the same problem should probably take a quick moment just to check this isn't it! :)
SOURCE: Netbook is not charging
I had a similar problem and called HP. The solution was to turn off the netbook and then hold the power button in the on position for about a minute to bleed the static charge build up. then to reboot the system and tap the f10 key. Do not save. Hit esc. instead. Press f9. Load the setup defaults.
then Power down. Restart the system. Call up the HP Support Assistant and check the battery.
If all of this is confusing, just call the hp Support desk at 800 479-6836 and HP will walk you through it all.
Best Always
Dave
