I have an LG Big screen TV and LG bluetooth soundbar on the 2nd floor
SOURCE: I HAVE A OLDER MODEL RCA HOME THEATER BIG SCREEN TV
I have the same tv at my place and I got Sears to come over and fix it. It cost me ~$90 for the initial visit then I ordered ~$140 part he recommended (voltage thing for crt) ordered and installed. He said that if that didn't work then he would have been able to return the part and it would have been the circuit board going out and that would have cost around $400 more. He said that if that were the case it wasn't worth it since you can buy one of these tvs used for around $500. The part he ordered worked on my tv and is doing fine.
I have an additional question though: is this tv HD ready for when all the signals change next year?
SOURCE: LG LCD TV - Buzzing Sound and Faint Horizontal Lines
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module. They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV. They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
SOURCE: i have a wharfedale i bar 10 soundbar and if i
where did u buy your ibar from i have one and its broke need to no where you can buy them
These
steps are for a headset that is already paired to you cell phone and is stored
in the phones trusted device / history list.
Look at
the lights on the Multi-Function Button of the headset (the top / largest
button of the three buttons); the light will be blinking Red if not
connected and blue if connected (paired and connected are two different things).
Push the volume up (middle button) 2 times, you should hear a beep each time
you press it. If you hear the beeps go to the next paragraph. If you hear no
beeps at all you will need to call 1-800-742-8588 for an RA # (Return
Authorization Number) for warranty and non warranty repairs.
Look at the lights on the Multi-Function Button on the headset
(the top / largest button of the three buttons); the light should be blinking Red if not
connected and Blue if connected (paired and connected are two different things).
Plug the headset into the power adaptor with power applied. Make sure your cell
phone is on and the Bluetooth power of the PHONE is turned on. After 5 seconds
unplug the headset from the charger and do not press any buttons. You should
get a slow Red blinking light at first. Allow the headset to connect
automatically to the cell phone, this may take up to 10 seconds. Once the
connection has occurred the Blue light on the Multi-Function
Button will blink once every second.
If after 10 seconds the light is still blinking Red once
every 5 seconds you will need to press either the Multi-Function Button of the
headset once to connect to the cell phone, or, your phone may be set up
requiring you press a designated button or sequence in the phone to connect to
the headset (meaning your cell phone is not set with or does not support
automatic connect).
*NOTE* Most newer model cell phones have an automatic connect feature. Some phones have the categories of
"Headset", and "Hands Free" in their Bluetooth menu. Some companies use the term Auto-Connect
under the "Hands Free" category in their Bluetooth menu to indicate the set up
for use with the Bluetooth system in an AUTOMOBILE.
Automatic
connection under the "Headset"
category and Auto-connect under the "Hands Free" category are not the
same thing. When dealing with the
headset you want to work in the "Headset" menu and make sure the Auto-connect
of the "Hands Free" menu is turned off.
If this doesn't correct the issue I'd recommend calling VXi at 800-742-8588 for additional clear and reset instructions and the possability of warranty repair options.
