Grasp the outside of the Flywheel really firmly and then using a piece of that rubber mat grip, grasp the inner wheel and turn it towards you. Sometimes if the machine hasn't been used for some time, the flywheel will get quite tight and you may need to apply some force. Is your machine the Blue top Star Series SU? Great strong workhorse machine. If you are a bit mechanical and what to delve into the machine, I'd suggest you find the Yahoo Group called Elna Heirlooms where owners of these Swiss made beauties share their passion and knowledge of these machines.
SOURCE: needle position
this wheel does seize over a period of time.Remove the top cover so that you can see the wheel. It can be unseized by spraying a mixture of 20% ammonia to 80% water under the wheel. Let it sit for 20-30 minutes, spray it again and then turn it with a pair of pliers. Do NOT break it!! use a soft cloth around it if you want to protect the wheel from scratches.
sewman7
SOURCE: how to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
SOURCE: Need parts for Elna SU Air Electric sewing machine
My Elna repair man is also the individual I purchased my Elna from in December 1980. His name is Boyd Albright, located in Ottawa, Kansas. I have never had the issues you describe, but Boyd has always serviced my machine and as far as I'm concerend, is the best. When I was told by another sewing machine shop in Mississipi that my machine could not be fixed, Boyd did and for less than $40.00! Contact info: 1231 S Willow St
Ottawa, KS 66067-3439
(785) 242-4340
He works out of his home as he is semi-retired.
SOURCE: flywheel on elna su wont turn
when a hand wheel won't turn then the machine needs to be serviced
SOURCE: Elna 2800 making noises when flywheel engaged
if the machine is new & it's already making noises, the I'd suggest taking the machine back & getting another
