If you are unable to pull the full bobbin off of the bobbin winder, take the thread of off the bobbin and it should come off easily.
If the thread has too much tension during winding or if wound at full speed, it can cause the bobbin to be compressed on the spindle and it won't come off. I recommend throwing away the bobbin just in case it was deformed in the process.
Wind at 1/2 to 3/4 speed in the future and make sure that it is threaded properly for bobbin winding.
Testimonial: "Thank you. Never had it happen in 15 years but your idea worked great!"
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
SOURCE: Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
