Garden Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 275 GT garden tractor with hydrostatic trans mission the fluid got low an would not move I bought fluid from dealership an installed fluid moved back an forth went to check level would not move is there a bleed valve on the unit to remedy the problem? or please advise what to do Grass is growing!!! The mower is around 10 years old an working great Thanks Ken Vick Hot Springs Ar. Email--- [email protected]
Anonymous
Level 2:
  • Expert 123 Answers
  • Posted on Aug 28, 2009
Anonymous
Expert
Level 2:
Answers
123
Questions
0
Helped
83867
Points
500
If the fluid was low and the mower stopped moving the hydrostatic will most likely need rebuilding or replacing. If it only started slipping changing fluid migh have saved it. You can jack up the rear with the tires off the ground and let it run in gear for a few minutes then do the same in reverse. Do this several times if it can be saved it will start pulling slowly when it does make sure it is still full of fluid let it down and drive it or mow with it. It could just be an air lock in the trans.
What would cause hydrostatic to stop working
Usually this is due to a low oil/fluid level in the transaxle. Over time, these units develop leaks. Just be sure to install the proper oil/fluid recommended for you unit.
Nov 15, 2015 • Garden
Kubota troubleshooting
chang filter and hydrostatic oil
Aug 27, 2014 • Garden
I want to know why my hydralic mower deck lift won,t work
Did you use ATF or hydraulic fluid? Possibility it is air bound?
3helpful
The mower gets slower and slower and then stops moving completely. I turn it off for five or ten minutes and it's okay ... occuring more frequently ....
The hydrostat transmission is low on fluid. Check your manual, some of these can be filled...most cannot. If yours can't be filled/doesn't have a fill opening, Husq is going to recommend to replace the transmission (sealed unit). There has been limited success by trying to top off the trans thru the vent tube. This is not a Husq approved repair, and is very slow and tedious. But it is a lot less expensive. Good luck!
Cub Cadet (105, I believe) hydrostatic transmission problem
you may want to pull the check valves out and make sure the ball arnt stuck if thay are it will do that just lube theme up with some wd40
Apr 20, 2010 • Garden
Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Sep 12, 2008 • Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
