Garden Logo
m
mo smith Posted on Jun 29, 2019
Can i remove the spray lance to attach to a patio cleaning head on homelite hpw080e
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on May 04, 2008
SOURCE: spray arm not attached
You may have stripped the threads on the spray arm or spray arm support. I believe the threads are reverse-threaded and since they are plastic, can easily be stripped if turned in the wrong direction. This has happened to me before. The solution is to replace the lower wash arm and spray arm support. You can find the parts at repairclinic.com. Just type in you model number and look for item numbers 830883 (spray arm support) and 9040141 (lower wash arm). You may also want to check out searspartsdirect.com as well. The parts will be located under the "Lower Washarm and Strainer Parts" section. The two sites do offer comparable pricing. Post back if you need further assistance. I hope this helps you.
Anonymous
  • 21 Answers
  • Posted on Dec 03, 2009
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Anonymous
  • 333 Answers
  • Posted on Jul 12, 2010
SOURCE: How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Sheldon Dedek
  • 912 Answers
  • Posted on Aug 25, 2010
SOURCE: Campbell Hausfield Pressure washer model
Most likely, the housing has split and seal is not being made. There is a chance that the hose is leaking where the fitting is crimped on (my experience, but different pressure washer). Are you able to see a leak when turned off but garden hose is connected and turned on?
Is it possible that water was still in the hose / gun and froze while it was in storage?
Tim Whalen
  • 3076 Answers
  • Posted on Nov 20, 2010
SOURCE: The device the sprayes water
I would make an access panel on the back side of the shower, this way if I ever need to access the shower lines/fixture in the future I can do so, Hope this helped Tim, here is a website that may help:
http://www.ehow.com/how_6071986_install-price_pfister-shower.html
Karcher K5 Premium Eco pulsing on low setting
Isn't there a bleed off valve on the unit. Typically they get stuck and pulsing is the result.
How to clean out the fuel reserve and line of the homelite 26b
Remove fuel lines at Carb. Blow carburetor cleaner through lines into tank. Spray carb. 1/4 cup carb cleaner into tank shake thoroughly pour out and repeat until clean. Blow out fuel lines into tank with compressed air and blow out tank with compressed air.
No water pressure when wand is squeezed
check the nozzle isnt blocked easiest way to do this is remove pipe from lance handle and see if it fires water at pressure when lance isnt attached if it does fire water at pressure then your spray nozzle is blocked or turned off at the nozzle the nozzle can sometimes spin to far round and close
Apr 21, 2015 • Garden
How can you remove a 7560w spray head?
  • Take out the plug button on the front side of the faucet handle and loosen the set screw with your Allen wrench, then pull off the handle. Remove the domed cap underneath the handle by unscrewing it.
  • Take off the entire spout by removing the mounting hardware under the base and lifting the spout up and off the faucet. The hose will be attached underneath the counter. Once you unscrew the connector, the spray head can be removed.
Karcher lance fitting
if they are the plastic version, replace them as they tend to "expand" as they age and won't fit properly.
Jul 08, 2014 • Garden
2answers
When the patio cleaner is attached,the Karcher 5.68 pressure washer now keeps stopping and starting.It works fine on high pressure lance.It worked fine when bought from new a few days ago. We tried...
None of these fixes works for me and the original poster, like me what he's saying is when he swaps the high pressure lance for the patio attachment it pulses on and off, but when that happens, you can swap back to high pressure lance and it's fine. This means it's the patio attachment not any valves or power source, I have the same problem
ONE OF THE SPRAY HEADS IN PATIO ATTACHMENT SEEMS BLOCKED
simple. find the smallest drill bit to fit the hole and run bit thru it. wala.
Karcher k3.99 pressure washer
go to the manufactures website for the answer as this is a washing machine help site eric
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
