Question about Maytag Washing Machines
Could a loose belt in my maytag neptune frontload washer cause it to be a unbalanced load,that has to be rearranged before continuing the cycle.
The unbalanced load has caused it to have vibrating or bumping noise in the final spin. However the noise lessons as it builds up speed. ?? Lynn
SOURCE:
SOURCE: maytag spinning loud noise
bearings are bad need to replace
Posted on Mar 14, 2007
venexcsd
  • 1185 Answers
SOURCE: My Maytag Neptune washer continues filling with water e
Does it fill when the machine is powered down?
If it does then the fill valve is stuck open and needs replacing
If it does not then you need to check the pressure switch and the air bell on the outer drum which probably has a ball of jellyfied soap in it.
If you take the back off you will see a thin plastic or rubber hose going from the bottom of the drum to a small flying saucer type object.
If you pull the hose off the bottom connection and blow into it you should hear a clicking noise from the pressure switch.
If it clicks then clean out the air bell and refit the hose .
If it does not click then get a new pressure switch
A repairman would test it live but that is not recommended for untrained people
Posted on Jun 22, 2009
dh1200s
  • 335 Answers
SOURCE: Not happy with Maytag Neptune TL Washer
I assume you are taking dc/UC errors to the console. This is a classic problem with the FAV6800AW/FAV9800AW after the 3yr to 5 yr mark. I own the machine and decided to learn what was involved to repair the machine. Take a look at this post and see if will give you some insight to a DIY fix to resolve the unbalance errors. No fix for the tumbler action of twisting up the clothes. After a re-lube of the one-way roller clutch bearing I could wash a single pair of socks or over load the wash basket with bath towels and extra water in the tub with no unbalance errors (dc/UC).
Shout back if you have any questions.
Here is a quick test for the TSD sensor but I believe you have a clutch issue. The TDS test is in the SM I’ve typed it out if you want to give a quick check. I’m sure you will pass and find the one-way roller clutch berings are dry/rusted and causing the dc/UC unbalance condition.
3.0 Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
3a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
3b. Press the Super Wash key display reads “in”…something like that.
3c. Press Delicates the Display will show “UC” (Unbalance Closed).
3d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
3e. Press Hand Wash.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube or replace if necessary. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
Posted on Jun 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Posted on Sep 27, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Maytag Neptune FAV6800AW Top Load Washer? makes a
kporter3
See this Clutch repair post if you want to DIY. Is your Wash tub banging around in Spin Cycle? Do you error out of Spin Cycle with dC or uC error code to the LED Console display? You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of Wash Tub movement and the Control Board shuts the Spin Cycle down……..so TDS is working as designed.
The machine will make several attempts to redistribute the load before the error code generation failing with dC or uC error codes. Please let us know what error coded you display.
I or other knowledge owners/DIY’ers or repair folks can help you. Please other forum members chime in for support.
Don’t get hung up in Front Strut issues or other WAG’s. Fix the Clutch Malfunction and your FAV6800A will be happy.
Aka dh1200s….. **** or Rich without the ****
Posted on Jan 03, 2010
My frontloader washing machine I(Neptune MAH
unfortuetly that is a common problem with that unit. it will continue to have wate in it afte the cycle has ended. i hate to say it but there is no solution for this proplem. I would recommend that you contact Maytag and let them know your disappointment. sorry for that news.
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Unbalanced load
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
UC code on may Maytag Neptune Washer FAV6800WW
Continuous Unbalanced Circuit. Improper signal from Tub Displacement Sensor.
Wet Clothes • Very small clothes loads can cause unbalanced loads - add additional towels. • Excessive suds may have been present. • Check Tub Displacement Sensor connection and main harness connector at machine control board. • Check Tub Displacement Sensor for 0 to 3.0 Volts DC output voltage between ground and the board input. Check for 12 Volts DC input voltage between the ground and the board output. Only check for voltage at the Tub Displacement Sensor. Do not perform a continuity check. See Tub Displacement Diagnostics • Excessive motion was detected in spin Run Quick Spin Test with an empty tub to check Tub Displacement Sensor and machine control board. • Check for restricted drain system.
Jun 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
This is a frontload Neptune. I think you will find that the motor control located in the bottom right front of the cabinet is bad.
Feb 07, 2009 | Compaq Presario 5000 PC Desktop
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
