Question about KitchenAid Microwave Ovens
Fuse location on kitchenaid kmhs120ess-4 over stove microwave/fan combo unit
  • KitchenAid Master
  • 9,176 Answers
You can find helpful Kitchenaid parts diagrams and get parts at affordable prices for most models from The Pros by entering your model number here:
http://tinyurl.com/gv383
Posted on Jun 30, 2019
    Top Expert:
  • KitchenAid Master
  • 54,386 Answers
Probably internal
Posted on Jun 28, 2019
6ya staff
SOURCE:
Anonymous
  • 100 Answers
SOURCE: microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Posted on Oct 31, 2007
Anonymous
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
Anonymous
  • 7 Answers
SOURCE: kitchenaid microwave hood combo KHMS155LSS
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME; while you are on vacation or at work or at night while you are sleeping etc. Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&E (Sears) out to fix it. Although they will fix the problem, if the keypad fails again, the underlying logic self start defect is still present. You should be under warranty if it is above model. Please be polite, insistent, but polite. With KitchenAid's pathetic quality in recent years, their customer service reps get more then an earful. Also, please go to the Consumer Product Safety Commision website at www.cpsc.gov and post a Report Unsafe Products report. This will help get this model recalled before someone loses their home or life. I almost had a fire this past Monday, Labor Day, 9/7/09 when my machine self started at 3 AM with a package of bacon left in it to thaw at room temp for the morning. What a smokey mess. Chinese made garbage. Shame on Whirlpool. Long live Hobart!, please buy back KitchenAid and bring back the lost quality.
Posted on Sep 09, 2009
Anonymous
SOURCE: GE Dual Wave II microwave oven blowing fuse
I have the same issue and the same unit. I wonder if there's a recall...
Posted on Feb 21, 2010
mathware
SOURCE: KitchenAid Wall and Microwave Oven Combo - KEMS308SSS
After using the microwave for a month, the amount of time to heat has increased significantly. For example, 1 cup water now takes 3 minutes to reach 158 deg and 4 min-40 sec to reach boiling (212 deg)
This model KEMS308SSS02 was installed in July 2008 in a new condo. It was never used until Feb. 2011 when we moved in as the first owners.
Any advice would be appreciated.
Posted on Mar 18, 2011
KitchenAid microwave oven model # KMHS120ESS-0 When you open the door the light doesn't always come on and you can't get the microwave oven to start because it thinks the door is open.
You either have an intermittent or defective door switch, or the latch assembly is not activating the switches properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 29, 2016 | KitchenAid Microwave Ovens
Kitchenaid khms155lss4 microwave combo went dead what fuse should i check frist
Check to make sure you are getting power to the receptical, plug a lamp to confirm. Next unplug microwave oven and remove top, "several screws" now look inside where the keypad is, follow the wiring to the circuit board, there should be a small glass or ceramic fuse clipped in, before you take it out discharge silver rectangular capacitor with a screwdriver across the points to make sure all voltage is removed. Now unclip the fuse and test, if open replace with the same current rating, if no change I recommend a technician to take it further. Please remember there is extreme high voltage when unit is plugged in and running making it lethal, put the top back on for safety sake.
Mar 02, 2012 | KitchenAid KCMS145J Microwave Oven
My wife slammed the door and now the microwave does not work. it popped the fuse box and also cut the power to the stove. i flipped the switch in the fuse box and the stove came back on but not the...
You can try to take the unit down and open the cage. Look at the door safety switches and see if they also popped out of place. She might have permanently damaged the door. But don't panic just try what I just explained. Turn off all power first at the breakers.
Jan 05, 2011 | KitchenAid KHMS155L Microwave Oven
Where is the fuse located on a kitchaid microwave khms155l
It is located behind the key panel. UNPLUG THE UNIT FIRST.
Remove top grill (2 sinked screws on top)
Now remove the single screw on top of the key panel. Barefully slide out the keypad up and out. The smart people of kitchenaid put the dang fuse jammed between the fan housing and the right wall. Remove the entire bottom plate that holds the lights and such... I think 8 screws. Now remove 2 screws that hold down the fan housing. Now you going to have to use a screw driver and some wiggling to move the plastic housing out of the way enough to pop and slide out the fuse and replace. To test you can use a continuity tester and place it between the fuse. There is nothing visible on this fuse (250Volt 20A fuse Fast Acting I think) e.g. you can't see that the fuse is broken or not. Make sure no wires are pinched while putting it all back.
Dec 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Power went out while cooking. Now light, and fan doesn't work either. Could there be a fuse?
Assuming that you have checked the voltage/breaker at the unit, There is a fuse located behind the user interface. You must exercise caution in this area as there is a high potential for harm due to the capacitor having been energized. If you are not comfortable/experienced handling high voltage, then I would strongly recommend calling for service. Hope this helps... Bill
May 29, 2009 | Kenmore 63792 Microwave Oven
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
I have an over the stove kitchenaid microwave w exhaust hood. About 1/2 hour after boiling water on my stove, my microwave comes on. I have unplugged the microwave-----any ideas?
The issue is probably your exhaust fan on your microwave comes on automatically when it detects a certain temperature. Mine does this as well but will turn off automatically after temperature goes down.
Feb 25, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
It sounds like there may be a blown fuse. The back of the mw oven will have to be removed to check. Some ovens only have a thermal fuse and not a traditional glass fuse. If that is the case you should call a technician to repair it unless you know how to use a soldering iron.
Dec 26, 2007 | Microwave Ovens
Microwave stopped working completely
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
