SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
SOURCE: Red key shaped light flashing on speedometer
The red key indicator is to do with your security system. When you turn the ignition on and put the handlebar control to the "RUN" position, power is applied to the fuel pump inside the fuel tank, that is probably the sound you are hearing.
The red key indicator usually flashes to show that the system is armed.
If you have a problem the only way to really find out whats going on is to have a dealer check the bike for trouble codes, this is usually done by connecting a computer to the data plug on your bike (this connector is usually found under the seat near the battery).
Hope some of this helped.
SOURCE: I have a Kipor KDE
Hi, I hope I can help a little bit. The hunting by the governor like can be caused either by governor adjustment or carb adjustment might be the culprit.But before you go into that, have you checked and cleaned the air filter or looked at the carburetor that might need cleaning if it has been awhile since that was addressed? If you figure that is alright try adjusting the carb first. I have never seen or heard about that brand of machine before, so I will give you a general adjust procedure. I will stress again to check everything you can think of first. The fuel tank has to be vented and on most machines this is done by the tank cap so make sure that is OK. Is the filter on the fuel outlet of your tank not obstructing the fuel flow and that the fuel lines are in good shape and not starting to deteriorate inside and slowing fuel flow?
To adjust the carb make small 1/8 of a turn at a time. Before starting the engine turn each one of the low and high clockwise or in until lightly seated so the needle seat is not damaged and remember that setting, even mark it down so you can always come back to that setting. The low or idle mixture screw should be about 1 turn out or counterclockwise more or less. The high mixture screw can be anywhere from 3/4 to 1 1/2 turns out or counterclockwise. Do not adjust the high mixture screw less than about 3/4 turn from the seated position. When you turn these screws in or clockwise it lets in less fuel to air and could make it run too hot.
Start with the high speed mixture screw and turn 1/8 of a turn out and listen what happens. If not better do that again up to one full turn in 1/8 increments. No good results try the low speed or idle mixture screw in 1/8 increments and see what happens. If no good try with the two at the same time.
There is one more screw and that one is on top of the carb and adjusts the idle or low speed of the engine with no load and is also very important to adjust the right idle RPM so that when a load is turned on it has enough RPM so the engine has enough so it does not start to miss and sputter because of turning too slow.
I have given you all this info without knowing if this is the right type carburetor or if this engine is gas or diesel, or is a barrel type carb.so I hope this helps you out even just a bit. All the best and good luck. By the way I will not even try to explain the governor setup as It is too lenghty and I don't want to make it run worse or not at all.
Maybe one of the other guys might have a simple procedure to get it done. Well good luck and all the best to you.
SOURCE: Hi, I from Indonesia and I need help... I have
maybe your generator has a problem with the cylinder head gasket.try to remove the cylinder head gasket,grind the valves intake and exhaust it. use the gasket cement to glue the cylinder gasket then assemble it
SOURCE: Iam looking to download a manual for a Kipor KDE
Try this link:
http://americanrvcompany.com/assets/images/Kipor/KDE5000ETA%20Operation%20Manual.pdf
