Exercise & Fitness Logo
Kathy Huneke Posted on Jun 27, 2019
Fan on my proform treadmill quit working. Used to work for a while and them shut off toward the end of the workout. Now it will not even start up. Everything else works fine.
johobikes
Level 1:
Habit-Forming:
Scholar:
  • Contributor 56 Answers
  • Posted on Jan 10, 2020
johobikes
Contributor
Level 1:
Habit-Forming:
Scholar:
Answers
56
Questions
0
Helped
30228
Points
80
They go bad all the time and are super basic, you can source one cheap through fitness repair parts.con
Amin Suleman
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 27, 2019
Amin Suleman
Contributor
Level 1:
Answers
Questions
0
Helped
5148
Points
7
Overheated - try cleaning the fan
  • Amin Suleman
    Amin Suleman Jun 27, 2019
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Apr 14, 2009
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Anonymous
  • 3 Answers
  • Posted on Sep 02, 2009
SOURCE: Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Anonymous
  • Posted on Jan 26, 2010
SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Jul 19, 2010
SOURCE: The incline on my proform treadmill is not working
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Anonymous
  • 944 Answers
  • Posted on Sep 25, 2010
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
I have a proform crosswalk 400e, and the circuit breaker on the treadmill trips whenever I plug it in
Many motor may have two stages, the first starts it turning and then the second stage takes over to keep it running. The 2nd stage of the motor may be faulty and drawing two much current or leaking current to the earth. Your breaker may not be the correct rating for the machine and needs uprating.
Something could have slipped in or moved around that could be jamming the belt or something else in the machine preventing it from starting up and causing an overload that triggers the breaker.
Proform Treadmill 785 E suddenly stops during highs speed workout
Use 2000W converter instead of 750W because you are using your treadmill on its full power on high speed. 750W converter is not capable of handling its full load resulting the machine malfunctioning. Your treadmill 785E have 2.25 CHP motor, 2.25 CHP is equal to 1677.824712W and 20-Amp minimum Ac outlet is required for your treadmill in order to function in full capacity. Download user's manual on: https://www.sportsmith.net/images/product_support/ProForm/PFTL785081%20-%20PROFORM%20I%20SERIES%20785%20E%20TREADMILL/PFTL78508.1-274823.pdf See Horse Power to Watts Converter on: http://www.rapidtables.com/convert/power/hp-to-watt.htm
Powered, but buttons do not function
please adjust the REED switch, TEST for open or faulty, clean it, and tight the plug or connector very well, see the diagram attached.
2) Tight the ribbon cable inside very well for keypads
3) replace batteries with the same types, same value, same polarity, and clean the contacts batteries.FULL charges.
God bless you
The breaker keeps tripping halffway through my workout on my proform 730 cs. why?
see my personall TIPS for to see the schematic.
2) Try to run the software calibration for diagnose and troubleshooting and fix it.
3) The c. breaker can indicate the motor, trafo, capacitor, or board is hot and trip the breaker.
sincerely. God bless you
2answers
THE PROBLEM WITH MY PROFORM IS THAT THE NUBS ON THE BOARD STOP WORKING SUDDENLY.ONLY THE START BUTTON AND SPEED 5 BUTTOMS ARE WORKING. WHAT IS THE PROBLEM
The overlay on the console is bad, proform doesn't sell just the overlay's so you will have to purchase the whole console to repair it.
1helpful
Treadmill squeaks
There's a special silicone-based treadmill lubricant that you put between the belt and rollers See this treadmill accessory kit
I have a pro-form 550 XL treadmill its in #10 deg. incline and wont come down. The motor keeps running trying to incline more and wont shut down or lower the incline. Reset it talked to sears rep. and they...
i ran into the same problem today with another proform model. i shut the machine off and lifted the platform to the stow position and brought it back down, turned it on. it worked fine during a workout. i was using an ifit sd card when it got stuck. were you? just wondering.
14helpful
I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
1helpful
2answers
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Treadmill shut down
No fuse, is only the complete Controller Board motor is faulty.
Some IGTBs had been failed. time to replace.
Sorry
LED Blink Patterns on the Control Board Treadmill
Blessing
[email protected]
cell+whatsAPP:+50588611441
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
