You do in good job.
If you want to learn more about diesel generator set technology support, or if you need to purchase diesel generators, you can contact [email protected], we can supply Cummins, Volvo, Perkins, Deutz, Ricardo etc. diesel generator.
SOURCE: atp3 wont power up why?
There is an internal fuse in the Altec Lansing Speakers ..BUT BE CERTAIN TO DISCONNECT THE POWER LEAD BEFORE MAKING THE FOLLOWING REPAIR.AS IT CAN BE DEADLY!!!
If you remove the larger screws from the back of the unit then remove the top section with the circuit board attached. Next remove the screws attached to the bass speaker as you will need to remove the speaker to replace the fuse.
Once the speaker screws are removed there is a little recessed slot in the timber for you to put two fingers in to lift the speaker out. It may offer a little resistence as there is a dab of glue holding the cables into the cabinet next to the speaker.
Once you have the speaker removed double check that you have disconnected the correct power lead to your ATP3.. The fuse is easily visible so pull it out and check with meters to see that it has not blown.
Alternatively take a 9 volt battery ( the type with both terminals at the top of the battery). Place your tongue over both terminals to verify it has a charge (you will feel a slight tingle on your . tongue).
Next place one end of the removed fuse on one of the terminals.. now short curcuit the other end with your tongue touching both the unconnected end of the fuse to the other unconnected terminal ... this should complete a circuit and give you a slight tingle.. ( it wont hurt you!) If there is no tingle the battery is either flat or you have a blown fuse.
If the fuse is OK, then chances are you have a faulty pin connector - your "right out" connector. Sometimes these get bumbed with the feet if you have it on the floor and they can lose the contact needed to switch your unit on.
You then need to either re-solder the pin out socket on the circuit board or repair the cable that plugs into it.
If someone has worked out how to solder a jumper lead on the board at the pinouts you may be able to have the power on permanently and then use the wall switch to turn it off and on.
SOURCE: Sharp R-1850A Mocrowave Convection - No power
Chances are if the internal fuse and magnetron thermostat are good, then you have a circuit board that needs repair.
You can probably find exploded views at the Sears parts site. If you find a bad thermostat, the best place to order Sharp parts is Tritronics.
We regularly repair these control panels for customers nationwide (RV owners & dealers, too) with our guaranteed $39.95 service.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
SOURCE: Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
