SOURCE: dstv to dvd recorder connection
SOURCE: connected my telefunken surround sound through my
telefunkin surround home theate system ? how do i connect my TV to my home theate? i dont see any sound outputs on the TV
SOURCE: Need to connect my DSTV decoder through my sony
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
SOURCE: black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
SOURCE: connecting pvr dstv decoder 3001
My pvr decoder model 3001 remote control doesn't work I checked battrey it works but no answer for decoder what shall I do
