Question about Maytag Washing Machines
What would cause my Maytag Neptune front washer to vibrate during the spin cycle, after it had a unbalanced load? Lynn
  • Anonymous Jul 10, 2019
    Start getting paid every month online from home more than $15k just by doing very simple and easy job from home. Last month i have earned $17954 from this online job just by giving this 2 hrs a day using my laptop. I am now a good online earner. Get this job you guys also and start earning money online right now by follow details here......................===>>>www.gocash7.com++
    Don't copy "++ " with web address
  • zino34435
    zino34435 Jul 15, 2019
    Every month makes more than $18k by just doing very simple job online. Last month i have earned and received $19649 from this online job by doing this for only 2 hrs maximum a day using my laptop. Very simple to do regular job and earning from this are just amazing. Everybody can get this now and start earning online by follow details on this website........
    HERE? ­­ www.profitclip.com
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Worn out drum Bearing can cause vibration and make the spin cycle very noisy.
Posted on Jun 27, 2019
  • 1 more comment
  • Allynn Wood
    Allynn Wood Jun 29, 2019
    Sorry just saw your answer. Thanks for the input. The machine was working great no vibration at all. Then on a load of towels it was spinning unbalanced. I stopped it as soon as i heard it and rearranged the towels and restarted it. It worked fine for the rest of the cycle. Then it happened again a few loads later. The vibration sounds like it's bumping on something the faster it goes the less noise it makes. Could it be that the off balanced load loosen a belt? I haven't looked inside yet. We'll see.
    Lynn
  • dmor81 Jun 29, 2019
    Ok, some machines have shock absorber(s) fitted to outer drum to reduce vibration.These sometimes need replacing.
SOURCE:
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
SOURCE: Front load washer shakes violently during spin cycle
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Posted on Mar 24, 2009
huuum
  • 750 Answers
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
SOURCE: major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Posted on Jul 25, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Noise hear during washing cycle?
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
BOYNISMO@YAHOO.COM OR 714-334-1998
Jan 14, 2010 | Maytag Washing Machines
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Washing Machines Logo
751 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
