SOURCE: Ryobi string trimmer -weed eater pull cord hangs out wont start
What model number is your Ryobi?
SOURCE: need to add new string to a weed eater xt 12
For manual go to;
Do it yourself repair: common repairs for a weed eater
Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor
or a leaf-blower after every use.
The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself.
window.google_render_ad();
If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws.
After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again.
Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
Preparation Instructions
SOURCE: String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Testimonial: "Thanks for the help. We did look at the coil. Got about 30 volts out of it when we pulled the starter. I hope that means it's OK."
SOURCE: replace pull cord Big Wheeled weed EaterString
First, remove the recoil assembly but dont disassemble!
You'll need about 3 1/2 ft. of the same size rope. Tie a knot into one end of the rope. While holding the pulley in place observe the direction the pulley moves when rope is pulled. Release pulley and cut and remove old rope. Continue winding pulley in direction rope would pull it. Do no wind too tight. Line up holes in recoil housing and pulley then push rope through pulley and out housing. Tie on handle and install recall in reverse order.
SOURCE: new weed eater 13" electric trimer, want to change the spool
Usually one get a a spool of the cutting wire and it snaps into place.
http://flymolawnmower.co.cc/reviews-Toro_Electric_Trimmer_Replacement_Spool_with_065_Inch_by_10_Foot_Line_88185-B00005V7KY.html
Shows you also how to do it on package.
