UNKNOWINGLY HIGH CENTERED ON TREE STUMP, NOW DECK WONT MOVE
SOURCE: cutting deck of mower not lowering
Did you check the wires goin to the motor under the frame to see if one of them came disconnected? Or...you might need a new switch.
SOURCE: Troy Bilt riding mower - blades wont turn
might need a new belt or bearings replaced or maybe grease the bearings
SOURCE: Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
SOURCE: LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
SOURCE: Hi I have a John Deere 345 lawn mower and the deck
Sounds like the deck is frozen up.
and the other sounds like a belt issue.
