Water Heaters Logo
Scott Walker Posted on Jun 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ECO Smart ECO 18 tankless water heater. Newly installed and the display shows an E5 code but there are no codes listed in the manual.
jws1013
Level 3:
  • Master 1,713 Answers
  • Posted on Jun 27, 2019
jws1013
Master
Level 3:
Answers
1713
Questions
Helped
458502
Points
6786
Ptg 74pvn 2 rtg 74pvp
copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Tankless water heater model # RTGL74PVN is blinking 38 what does this mean
Copy following link for general troubleshoot and error codes:
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
2answers
I am geting a P1 error code
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
3helpful
2answers
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
C2 11 is no ignition.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Have Error code FO, no hot water. Press reset and water gets warm for few seconds then goes off again.
1) BOSCH website shows error codes.
FO does not appear:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
2) I do not see FO error code listed on Internet search
Other FO questions at fixya seem to have no answer:
http://www.fixya.com/tags/error_f0_bosch
3) At this point, I would suggest calling a service technician.
While waiting for service, read manual cover to cover several times.
4) Your manual is valuable resource, and shows the word 'maintenance' and 'troubleshoot' frequently.
Tankless are maintenance heavy, and should be de-limed each year.
U-tube search "delime tankless water heater."
5) Also explore Bosch website for your manual and other valuable information.
6) When service tech arrives, ask that person for tips and tricks about your unit that will help you maintain your water heater.
7) All costs are energy. Install DIY tank-type gas water heater and avoid the whole headache.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Bosch 250 sx ng tankless water heater showing error code. checked fuses and they are fine. tried resetting many times still not working
BOSCH error codes:
Best place to start is troubleshoot section in manual. Page 24
http://www.boschhotwater.com/Portals/7/TechManuals/250SX_English.pdf
Problems range from air supply, gas supply, venting, part failure or combination of listed things.
Don't forget, tankless require yearly maintenance, outlined in manual, and cannot be exposed to more than 11 grains hardness in water, and should be de-limed each year.
I suggest reading entire manual several times, so you are pro about your tankless water heater.
Even with this knowledge, trained service technician will have to be consulted
some day, and tankless should never be installed if factory trained technician not available in area.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
Install tank type water heater that can be put online when Bosch is not working
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
I am getting a IL code on my display
IL code is: water heater has lime deposits.
Tankless should be de-limed each year using white vinegar..
Search U-tube for "de-lime tankless heater" to see how to do this yourself, or call service technician.
There are special fittings that can be added to tank at the hot-n-cold ports that let you easily de-lime your water heater each year.
Typical manual shows error IL on page 33:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Typical manual also shows regular maintenance on page 29.
The word maintenance is used throughout the manual.
Research shows that regular de-liming will not restore full efficiency to tankless water heaters:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
