Televison & Video Logo
Pat Haitz Rau Posted on Jun 27, 2019
I have shinco model no, SDZI-50P could you tell me when and how long I should run the Dry Key mode?
DOES 50P MEAN SOMETHING ?
Not knowing what brand it is I think the 50P is a model number. Has nothing to do with power or charging capacity.
tip
50p/60p Converter-Transcode CX360 MTS to ProRes for FCP X Editing
Merge/Edit Sony CX360V 1920x1080 50p/60p AVCHD to ProRes 422(HQ)(*mov) on FCP X with Highest quality <br /><br />I used Sony HDR-CX360V to record 1920x1080 50p/60p AVCHD MTS files, which are not compatible with FCP X. So in order to edit the movies on FCP X, conversion from <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS in 50/60 progressive mode to ProRes</a></b> is necessary. <br /><br />I've tried Clipwrap, Toast and Aunsoft to carry out the conversion. Clipwrap failed because it cannot export 50/60 progressive mode; Toast completed converting but the quality is badly affected. <br /><br />Only Aunsoft Final Mate for Mac successfully converted the 50p/60p MTS to ProRes 422 with no loss of quality. I really want to say that it is the best software to <b>Transcode Sony HDR-CX360V 1920x1080 50p/60p AVCHD MTS footage for FCP X</b> that I've ever used. <br /><br />Here is the step-by-step guide to quickly <b><a href="http://canon-videoconverter.com/2011/07/transcode-sony-cx360-50p60p-avchd-mts-footage-to-prores-422-hq-for-fcp-x-editing/">Convert/Edit Sony CX360 50p/60p MTS to ProRes 422 (*.mov) on FCP X</a></b>. <br /><br />1. Importing 50p/60p AVCHD MTS files to Aunsoft Final Mate for Mac <br />Use a USB cable to Connect Sony HDR-CX360V to Mac. Follow the popup window and wizard to complete the import. <br /><br />2. <b>Merging and converting 50p/60p AVCHD MTS files</b> to what you want. <br />After the MTS movies are imported, select one or several videos you would like to convert and then drag and drop them to Movies tab. You can choose the files to be joined as one whole, or create a single movie for each file. Then click the "set parameter" button. Choose Apple ProRes 422(HQ) (*.mov) under Final Cut Pro as its output format and choose "50" (or 60) for the frame rate. <br /><br />3. Export Apple ProRes 422(HQ) for editing on FCP X <br />After setting the output format and frame rate, click the "Export" button and conversion from <b>1920x1080</b> 50p/60p AVCHD MTS files to Apple ProRes 422(HQ)(*mov) starts. <br /><br />After the conversion is completed, <b><a href="http://www.aunsoft.com/final-mate-mac/">Import and Edit ProRes 422 (HQ) on FCP X</a></b>. <br /><br /><b>Tips:</b> <br />If you want to join/merge Sony HDR-CX360V AVCHD MTS clips and <b>play on WDTV Live with original quality</b>, you can use Aunsoft Final Mate to import MTS files and flawlessly export MKV without transcoding.
I am trying to get a users manual for a Shinco pmp 1700 multi media portable player.
I've not been able to find a digital copy of the user manual for you, your best bet is to contact shinco for a user manual and see if they can send you one over email or mail you a physical copy.
Here is their email address [email protected]
you can also try
HC SHINCO (USA), INC.
330 Turnbull Canyon Road, City of Industry
CA 91745
Tel: +626 968 8827
E-Mail: [email protected]
[email protected]
bill@shinco.com.sg
2helpful
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Seeking battery unit for a Shinco DVD player model SDP-5880
a. where did you purchase it? b. have you tried their web-site? (shinco). try getting info from your point of purchase- good luck with that! try googling brand name, model #, part# and see if there is any source for a 'generic' replacement battery. depends on how old your unit is, to some degree. shinco may be out of business!!
good luck!
Shinco digital camcorder dvc-818
Hi my one is that Shinco digital camcorder s1000b .I still havn't known how to input e-book function.I'd tried copying (in put) from computer pdf as wella s adobe redaer 9 files but noting had happing .So what can I do for this e-book function ? Please tell me quickly.
My e mail address is that "[email protected]"
Thaks
Hlahtut
22helpful
4answers
Top Shinco Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
